It is currently Mon Aug 04, 2025 1:48 am
 Post subject: oil filter thingo
PostPosted: Sat Sep 16, 2006 5:32 pm
on the oil filter holder, there is the pipe that goes from the top end of motor to the oil filter, now at the oil filter end of pipe there is a threaded thingo that joins the pipe end to the filter housing, i need this threaded thingo, and was wondering if anyone had any ideas on where i can source this at this hour of the day?
i'm freaking out man!
PostPosted: Sat Sep 16, 2006 6:11 pm
umm... i'd just source a new pipe with the tthreaded thingy already attached.. think it mite be easier than just gettn the threaded thingy
- '74 Clubman Ute project
PostPosted: Sat Sep 16, 2006 6:22 pm
oil return line, thats what its called! and mmm i think i might have to source one. shizen
PostPosted: Sat Sep 16, 2006 6:24 pm
surely theres mini people your way with old bomby motors that have it still on.. good luck dude
Clae
PostPosted: Sat Sep 16, 2006 6:27 pm
there are some, but the local footy celebrations are with the people i know. and the other people i have only met when they stopped to give me there number for mini parts... those people are always suspicious :shock:
PostPosted: Sat Sep 16, 2006 6:34 pm
i'd be doing the hose method as in stated in here
http://www.ausmini.com/forums/viewtopic ... ight=bling
PostPosted: Sat Sep 16, 2006 6:49 pm
cheers, now to figure out what it all means! and make it.
PostPosted: Sat Sep 16, 2006 6:53 pm
its replaceing the metal pipe with a Pirtec high grade piping with connection
PostPosted: Sat Sep 16, 2006 6:54 pm
but whats bsp?
PostPosted: Sat Sep 16, 2006 6:58 pm
Brittish Standard Pipe thread
PostPosted: Sat Sep 16, 2006 6:59 pm
um..I guess thread style
PostPosted: Sat Sep 16, 2006 7:02 pm
why thank you all for your help, it seems like i may have some work to do very soon
PostPosted: Sat Sep 16, 2006 7:05 pm
:lol: at me
PostPosted: Sat Sep 16, 2006 7:36 pm
You are after a flare nipple to suit the pipe, with a `1/4 BSP male' thread to screw into the filter.
Easiest solution- go to Pirtek or EnZed and take the pipe... :wink:
note a 1/4" BSP thread is much bigger diameter than 1/4"- as it's a pipe thread it's sized by the bore of the pipe. :wink:
ie. a 1" pipe is much bigger outside than 1".
PostPosted: Sat Sep 16, 2006 7:40 pm
cheers doc, are either of these places likely to be open on a sunday?
