It is currently Sat Aug 02, 2025 8:46 am
PostPosted: Mon Sep 18, 2006 1:07 am
A) The head on my 1430cc has the extra studs. Now the rocker cover I have leaks, even when a brand new gasket is used. Cono at Minicraft mentioned something about "it's a good rocker cover, but not with the extra studs". So the Q is, what's the best, standard nice chromy rocker cover to use?
B) My gear selector stick is loose. It's really wobbly, and because of it's wobbliness, vibrates and buzzes loudly as the car rumbles along (annoying? YES!). I have no problem changing/selecting gear what-so-ever, in fact, it's incredibly smooth. Why is it so loose? How can I fix it? ----- POSSIBLE ANSWER: It doesnt have a boot on it.
Jonathan
PostPosted: Mon Sep 18, 2006 2:15 am
If it's a rod change the thing on the bottom (flange? or whatever it's called) might be gone. You can buy kits for them; just need a hole punch and some patience.
Shard
PostPosted: Mon Sep 18, 2006 3:02 am
Actually, I might need a new boot for the gear stick.
<EDIT> On second thoughts, it doesn't even have one on there at the moment! I thought something looked funny!
Jonathan
PostPosted: Mon Sep 18, 2006 7:46 am
Any alloy rocker cover is better than the bent tin ones. :lol:
Why- because they are FLAT.
Neither of mine ever leak.
re the gearstick what box is it- if it's remote, the nylon ring may be worn out so the spring cannot do its job..
PostPosted: Mon Sep 18, 2006 12:26 pm
its a rod change.
Jonathan
