It is currently Tue Aug 05, 2025 11:16 pm
 Post subject: White Roof
PostPosted: Wed Sep 20, 2006 2:33 pm
Does the white stop inside the channel on top of the roof or does it stop under the lip of the channel?
Basically - where do i put the masking tape to mask off the rest of the car?
PostPosted: Wed Sep 20, 2006 2:44 pm
Originally the white was on the top side only , so the top of the gutters and roof were white , the outside edge and underside of the gutter was body colour . Hope that hasn't confused things further ...
PostPosted: Wed Sep 20, 2006 2:46 pm
Usually the inside of the gutter (the wet bit :roll: ) is the colour of the roof and the outside is the body colour. If you were to fit a cover strip around the gutters edge (like the bottom seam under the doors and over the arches) it would separate the colors
Hi Miniboy,
My '66 has a white roof and the slit line is the top edge of the gutter, so white right up to the top on the inside.
Regards
Al
 Post subject: Re: White Roof
PostPosted: Wed Sep 20, 2006 3:05 pm
On the outer part of the roof gutter, all around.
PostPosted: Wed Sep 20, 2006 5:15 pm
Thanks for that guys.
