It is currently Sat Jul 19, 2025 3:36 pm
 Post subject: Pulling
PostPosted: Tue Oct 19, 2004 7:01 pm
Ok i've just had my steering rack replaced (or steering shaft or something or rather) and it's so much improved. THe shaft was bent like a banana and steering was absolutely terrible.
Now since i've had it, it pulls to the right quite a bit when i accelerate, then goes back off to the left when i decelerate.
Kevin (the man at minitech) said i would need a wheel alignment, and its been a month or so since i've had the rack/shaft/somethign replaced.
Is it just the wheel alignment or something else?
Wheel bearings? CV joints?
Let me know.
 Post subject: Wheel Alignment?
PostPosted: Tue Oct 19, 2004 7:13 pm
Did you get a wheel alignment when you replaced the steering rack?
Might be a good idea! :wink:
PostPosted: Tue Oct 19, 2004 7:23 pm
Nope not yet; he said i'd need to... but if its not that... hmm.
Maybe i'll book it in for a wheel alignment soonish.
PostPosted: Tue Oct 19, 2004 7:32 pm
You Big Wolly....Book your self in......tomorrow and all will be fine..There is no way he could have got it perfect with a rule
PostPosted: Tue Oct 19, 2004 7:43 pm
Yeah :lol:
But would this fix the pulling when i accelerate and decelerate?
PostPosted: Tue Oct 19, 2004 8:56 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
ya it will cos as you applie power the wheels will pull and if the angles are wrong it will cause this also it will ruin yer tires so tomorrow is a good option and i would not like to drive it in the rain
makka
PostPosted: Tue Oct 19, 2004 10:10 pm
I'm not gonna make any excuses for this comment: I reckon it's funny that someone called "big willy" started a thread called "pulling"
sigh....
My van, and the cooper s before it changes direction on and off power, I found that one of the collar bone shaped thingys that goes from the tie rod end to the hub had it's bolts a bit loose - I removed, cleaned, checked and locktited them up and it made it a bit better, but it's still there. I asked one of the mini places in Melbourne about it and they said it's normal to have a bit - I've got Cooper S unis, apparently they're known for it, but I'm not sure about that... my other Cooper S does it too, but not as much, would be nice to get rid of it. My clubby pot jointed Mini K never did it
PostPosted: Tue Oct 19, 2004 10:50 pm
bah ha ha ha....big willy....pulling..... :lol:
Yea mate, wheel allignment pronto!! When you replace your rack, the tie rods are screwed onto the ends. Thats where the adjustment is. You can only get that right with the right gauge.
PostPosted: Wed Oct 20, 2004 6:36 pm
Wheel alignment - booked for Friday (22 Oct) morning 8)
PostPosted: Wed Oct 20, 2004 7:01 pm
Might want to also check the 'U' bolts in the floor, about a month after I had my steering rack changed they seated in and came a bit loose causing all sorts of weird steering behaviour.
PostPosted: Fri Oct 22, 2004 6:16 pm
ok took the car for wheel alignment; he had a jiggle with the front wheels and said he cant touch it. He told me to take it to a specialist to fix up the slopiness in the LHS wheel. I was crying at this stage (not really) coz i thought it was something major. This was the thing that was causing the erratic steering. (pulling on throttle).
He told me to go to Pulse automotive a few shops down and see Tom - a mini nut.
I did that and he pulled the wheel off and had a quick look; the nuts on the steering arm where they join the hub were quite loose. Out comes the socket and tightens them up. I thank him greatly, as he didnt want any money, and i was on my way... with a mini that doesnt steer itself when i take my foot on and off the accelerator.
Awesome... the mini is fixed again :D :D :D :D :D :D :D :D
PostPosted: Fri Oct 22, 2004 8:21 pm
you now need to buy tom a nice hat
Inconspicuously Conspicuous
PostPosted: Fri Oct 22, 2004 8:26 pm
Or get mum to make him some lunch :P
PostPosted: Fri Oct 22, 2004 8:54 pm
now go get ya wheel alignment, silly willy :lol:
PostPosted: Fri Oct 22, 2004 8:55 pm
I will! He said come back monday coz both the hoists were full after i got back from getting the dodge wheel fixed 8)
