It is currently Mon Aug 18, 2025 5:11 pm
PostPosted: Sun Nov 05, 2006 2:30 pm
Looking for a flywheel puller for hopefully one quick job. Was hoping for this arvo but if too soon then some time this week.
Would like to make Kev's puller but can't get my hands on the steel plate. Anyone have some spare 3/8 plate?
Edit:Just found and old BBQ that may work but still need a puller in the short term
David L
PostPosted: Sun Nov 05, 2006 4:53 pm
can you bring the engine around to here David???
I have the hydraulic one here if you`re keen
Matt
PostPosted: Sun Nov 05, 2006 6:00 pm
Thanks Matt - I'll think on it - may be difficult but desperation is the mother of ingenuity
David L
PostPosted: Mon Nov 06, 2006 11:15 am
I rigged up a puller using the middle part of an old flywheel and a couple of head studs. Works great. You can come around & borrow it if you want. Windsor near centre of Bris.
M
PostPosted: Mon Nov 06, 2006 3:06 pm
Bug*er ! Servers at work have been down all morning and I was figuring to hire a trailer and drive across town to Matts I may as well buy one - So I've just placed the order with Karcraft :evil: :evil:
Anyway I will now have one if anyone in Brizy needs one
David L
PostPosted: Mon Nov 06, 2006 4:28 pm
Hi David,
You have ordered the sykes pikuvant remover? They are very good, however buy some quality high tensile bolts from your local bolt place to replace the standard ones in the kit. (Make sure you replace the right ones, as they include bolts to suit the A+ flywheel as well.)
The standard ones just strip their threads in the flywheel, and you run the risk of damaging the flywheel threads at the same time.
The high tensile bolts fix this!
Matt
PostPosted: Mon Nov 06, 2006 5:55 pm
Thanks Matt - will do.
I've notice that a PO (or someone) has at least tried to get the flywheel off. There are some "persuasion" marks on the centre cone and one of the holes for the puller bolts has a chunk out of one side - fortunately only about 2 threads missing on that side and there is a smaller piece missing off the lip of another hole, so I don't wish to risk further damage.
Question: with a piece missing like that would the balance be affected to the extent a rebalance of the flywheel would be in order?
David L
PostPosted: Mon Nov 06, 2006 9:05 pm
Not enough to worry it at all man,,, you`re not going to be racing it at 7000rpms & above are you???
Users browsing this forum: No registered users and 116 guests
