It is currently Sat Aug 16, 2025 5:09 am
 Post subject: what carby to use
PostPosted: Sun Nov 05, 2006 8:22 pm
1100 motor with 12g295 head. What would be the best carby to use. I have a single hs2, hs4 or hs6 to choose from.
Thanks, steve
PostPosted: Sun Nov 05, 2006 8:23 pm
hs6/hs4 depending on what extractors/zorst/headwork
PostPosted: Sun Nov 05, 2006 8:36 pm
Perry extractors, head is pretty standard I think.
PostPosted: Sun Nov 05, 2006 9:15 pm
Use either the HS6 or the HS4 - HS2's barely worked well on smaller motors but both should work equally as well provided it has the right needle for your particular engine.
The beauty of an SU is that it only sucks what it needs (fuel/air) at any one time when the needles are right. The HS6 will allow a bigger flow than the HS4 when and if the engine wants it though.
GR at a recent Mini car club meeting told us (the audience) that he had a small bore 1100 motor not dissimilar to yours on the dyno and at peak revs it had a HIF44 with the piston right up at the top and it was sucking all there was to suck.
Give me a few minutes and i will find out what needles WinSU suggests for your motor, for each carby, as a starting point.
PostPosted: Sun Nov 05, 2006 9:24 pm
WinSU suggests a ABK needle as a starting point for the HS4
A BDF needle as a starting point for the HS6
Remember this is not gospel - just a guide provided by a software provide as a startiing point.
PostPosted: Sun Nov 05, 2006 11:54 pm
if the motor was standard i'd tend towards a hs4, but with a 295 head, i guess the hs6 is the way to go
Users browsing this forum: No registered users and 307 guests
