It is currently Sat Aug 02, 2025 9:55 pm
PostPosted: Wed Dec 20, 2006 9:26 pm
am i right in thinking i only have to tighten the oil filter by hand and shouldnt tighten using the strap that i used to take it off
i know i read it somewhere but cant remember
just hand tighten ?
thanks in advance
PostPosted: Wed Dec 20, 2006 9:34 pm
Hand tight.
Not as tight as you can manage either, you'll know when it's right. :D
PostPosted: Wed Dec 20, 2006 9:35 pm
For ryco filter it says to turn 2/3rds of one turn after contact with gasket, this is easily achieved by hand. Just check for leaks after warming engine up
Daniel
 Post subject: Tighter
PostPosted: Wed Dec 20, 2006 9:36 pm
I assume a spin-on. Slightly more than hand tight...unless your name is Schwarzenegger.
The idea is to bring the rubber gasket up to the mating face and then slightly compress it....say 1/2 to 3/4 of a turn after contact with the filter wrench.
The last thing you want is for the filter to unscrew through vibration and dump your oil.
PostPosted: Wed Dec 20, 2006 9:38 pm
thanks heaps guys i will tighten it a little more tommorow morn
PostPosted: Thu Dec 21, 2006 8:25 am
make sure you've oiled the rubber lip otherwise you'll have a hell of a time getting it off
Lillee - 1969 Morris Mini K
