It is currently Fri Aug 15, 2025 5:16 pm
 Post subject: wheel lock removal
PostPosted: Fri Dec 22, 2006 8:37 pm
ok i lost my wheel lock socket i have looooked everywhere and will have one last look tommorow - i know im an idiot as i also misplaced the packet with the codes for replacements
would this kit actually worked how do you all get them off surely someone has bought a car with them on and had no socket or suffered the same prob
http://www.sjdiscounttools.com/lt4000.html
PostPosted: Fri Dec 22, 2006 8:47 pm
Hammer and cold chisel worked for me.
I was mad too when I lost it.... :x
Then I thought- meh, they're only crappy old Contessas, who would steal em... :lol:
PostPosted: Fri Dec 22, 2006 8:54 pm
yeah thanks doc
i actually had the car booked in for matt to do somethings to it brakes etc and got up looked around and swore for about two hours
then called matt :oops:
he suggested chisel
went to the wheel shop and they wernt much help said to use a drill but dont wreck the wheels :roll: yeah thanks
PostPosted: Fri Dec 22, 2006 8:56 pm
hmm whith toold like that out, nothing is safe
:roll:
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Fri Dec 22, 2006 11:11 pm
The old trick is the slightly smaller socket (cheapo) and hammer it onto the lock nut. Obviously if yours is an internal (like allen key) this won't work.
Daniel
PostPosted: Sat Dec 23, 2006 5:46 am
Most lock nuts for Minis are round with an external keyway, the BFH & chisel undoes `em fine... :wink:
PostPosted: Sat Dec 23, 2006 7:35 am
this was my way last time i had to remove wheel locks without the key
Rover 214 atm ....
PostPosted: Sat Dec 23, 2006 8:52 am
hey are you trying to remove a contessa wheel lock, i sold my contessas but the bloke didnt take the lock nuts, i have the "unlocker thingy" if you want,
hey doc, hows steve oing with those wheels, are they still too close to the trailing arm or...
PostPosted: Sat Dec 23, 2006 9:10 am
so you take a chisel and lign it up in the centre of the nut and smack it hard with a bfh or you pry it off with the chisel
am i trying to spliy the nut in half :?:
 Post subject: lock nuts
PostPosted: Sat Dec 23, 2006 9:22 am
You can take it to a bob jane or a tyre place and they will be able to rip it off with an air gun and some secret tool. I did this to for my mate after he lost his key, they charged me about $20 - $40 bucks. You should bring spare nuts because no, you will not be able to re-use the lock nuts!!!
PostPosted: Sat Dec 23, 2006 9:37 am
They are fine, no problem.
`Mini offset' Contessas are designed for the flat drums on a deluxe or K... :wink:
Just legal with no flares. 8)
PostPosted: Sat Dec 23, 2006 9:42 am
yeah i will try a different bob jane and after xmas as the one i went wasnt much help
PostPosted: Sat Dec 23, 2006 10:18 am
You can use one of those "universal sockets" that are sometimes sold in crap stores.
Looks kind of like a spark plug socket with lots of little rods inside it,
when you push it over the nut the little rods conform to the shape of the nut.
Sell for under $10, but they don't last very long (the little bits break off)
PostPosted: Sat Dec 23, 2006 7:47 pm
I had exactly the same problem recently with the Alfa 75..Worked a treat :wink:
PostPosted: Sat Dec 23, 2006 8:07 pm
I used to just get a wheelnut and weld it to the lock nut. On the next wheel I would weld the wheel nut and lock nut from the first wheel.
When you finish you have four lock nuts and a wheelnut welded together. 8)
