It is currently Wed Jul 23, 2025 3:51 pm
PostPosted: Mon Jan 15, 2007 10:50 pm
I found these rims and I was wondering what problems one would encounter fitting them. They can be drilled to custom PCD's, so could fit minis, but with the gap in the middle i'm not sure whether problems would arise. The wheels can come in +5mm offset or -35mm offset and are, as in title, 10*5's...
Thanks.
http://www.motosportalloys.com/Wheels/large/SportliteR.jpg
PostPosted: Mon Jan 15, 2007 10:53 pm
lol ... that look .... veeeerrry deeep
yea the centre emptiness would be a bit of a weakness tho
'94 Honda EG4 Civic. -Daily-
'95 Honda DC2 Integra
PostPosted: Mon Jan 15, 2007 11:53 pm
nice looking rims, wher abouts can u get em?
or do you have to order from america???
PostPosted: Tue Jan 16, 2007 6:51 am
They are ATV (All Terrain Vehicle) rims from america.
PostPosted: Tue Jan 16, 2007 7:08 am
Ahhh , potential problem then , they may be only rated to support a 250 kg vehicle and rider package , not a 6-700 kg car/passenger/luggage package , hard cornering under load may see them break .....
PostPosted: Tue Jan 16, 2007 9:58 am
A question to the company about weight limits wouldn't go a stray then??? I've found others that I like now and they dont have to emptiness in the middle, but I will still enquire about the weight restrictions.
PostPosted: Tue Jan 16, 2007 11:20 am
Not only the weight capacity....... but if you have an accident and the insurance company inspects your vehicle, they could decide not to pay out because the wheels are non ADR compliant, or not intended for use on a road registered motor vehicle.
They do look good though.....
PostPosted: Tue Jan 16, 2007 11:39 am
When fitting aftermarket wheels you want to make sure they meet Australian standards, which will be stamped somewhere on the wheel. I doubt those ones do and I'm not sure I'd even trust them on a boat trailer :lol:
PostPosted: Tue Jan 16, 2007 12:31 pm
I'd recommend you to stick to road designed wheels. You can get a huge range on 10 x3.5 (LOL) up to 10 x 6 from trailer places, And they have the same stud pattern as a mini. But the clearly have 'For Trailers Only' embossed on them, I reckon those wheels would fall into that catagory.
PostPosted: Tue Jan 16, 2007 12:33 pm
Yes , I've seen a lot of these that are suited to light boat trailers and the like , but definitely not mini's , especially if you like to have fun on corners , results could be catastrophic . Whatever wheels you are interested in , make sure they are up to the load and have approval .
Users browsing this forum: 1071 S and 83 guests
