It is currently Fri Aug 22, 2025 9:10 pm
PostPosted: Wed Jan 31, 2007 7:43 pm
hi, does the bores have to be honed a special way or offset to make the increase of bore size. Are you able to just do a standard rebore like anyother car engine.
thanks
PostPosted: Wed Jan 31, 2007 7:47 pm
No offset bore required.
PostPosted: Wed Jan 31, 2007 7:55 pm
i thought it was a stroker kit that did it
PostPosted: Wed Jan 31, 2007 8:08 pm
hi, thanks, so just a standard hone
PostPosted: Wed Jan 31, 2007 8:10 pm
You need a bore... not a hone.
A hone is what is done to a bore to help the rings bed in.
PostPosted: Wed Jan 31, 2007 8:11 pm
It's just a standard rebore, no stroking needed.
PostPosted: Wed Jan 31, 2007 8:33 pm
Online
You can do a standard alignment bore job to 1360cc (73.0mm).
GR did 2 for me like this, one will be stroked to get 1412cc..
Some people offset the bores a bit to make the spacing equal, this was a good idea on 1380 (73.5mm) bores as it meant later you could bore to 1400 (74mm) without getting too thin between #2 and #3.
However, 74mm pistons lately appear to be rocking horse doo doo, so it's probably less important now.
Users browsing this forum: Bing [Bot], drmini in aust and 193 guests
