It is currently Fri Aug 22, 2025 12:00 pm
 Post subject: Need help with Radiator
PostPosted: Wed Jan 31, 2007 10:24 am
what is the difference between a 2 core and a 4 core radiator and what will be better for a 1275??
the price difference is very similar so i don't know which one to get
thanks
1967 Morris Mini Minor - 1380 cc 45mm weber, leather interior, MP3 player with 4' Kicker spits alpine 6x9 and 10in JL sub and Kicker 4 channel amp.
PostPosted: Wed Jan 31, 2007 12:48 pm
2 cores :lol: I'd assume the more cores, the better throughput of coolant therefore more efficient cooling. But unless you have overheating problems, 2 core may be quite ok. There is good authority for having optimum operating temp :)
PostPosted: Wed Jan 31, 2007 6:28 pm
2 core UK one is OK, it has BIG cores and lots of fins.
4 core UK is also OK I hear, but it's a bit wider..
3 core UK cheapo, don't bother- :x it is flimsily made and has only 8 fins/inch, where an Oz Mini rad from 1965 on has 16.
I just took the 6 months old UK 3 core out of the 1360 and refitted the Oz S one after it was serviced. Motor is now running at 1/4 scale again with the 82C thermostat, instead of 1/2..... 8)
PostPosted: Wed Jan 31, 2007 7:03 pm
Bruizer firstly used UK 4 core needed modification as these were designed for under clubby bonnet and chip paint under a roundy bonnet. I later learned mini spares who developed the 4 core went on to develop the 2 core supa flow better and thinner for under roundy bonnet.
The Austin and Bruizer use the 2 core farking fabbo
Steve
PostPosted: Wed Jan 31, 2007 7:08 pm
I had to mod the body a bit for that UK 3 core, at least now I have plenty clearance on the Oz one... :lol: 8)
PostPosted: Wed Jan 31, 2007 8:02 pm
thanks guys
i think the 2 core is the way to go
