It is currently Fri Aug 22, 2025 12:11 am
PostPosted: Wed Feb 28, 2007 5:16 pm
I need to remove 1/4 windows from my clubman so I can get painting, how the hell do they come out?
Cheers Ian
Ian - My Ve SSV Ute - Looking for a Mini
PostPosted: Wed Feb 28, 2007 5:27 pm
use a cold chisel to knock the screw heads off if that dont work just smash the glass or you could paint over them
PostPosted: Wed Feb 28, 2007 5:30 pm
Really helpful Allan ....
Undo the two short bolts on the door proper (behind the door card , have a look and you'll see the ones I mean) , then the screws on the outer edge of the window frame . Wind the window down and pull the top of the quater window towards the rear of the door , then lift it out when you can . They are very easy really , only a problem if the screws at the top are rusted .
I have unscrewed the screws, do I need big window out aswell?
PostPosted: Wed Feb 28, 2007 5:31 pm
How about the two bolts in the door ? You wind the window down to get the quater out then you can pull the main window out .
PostPosted: Wed Feb 28, 2007 5:33 pm
i didnt know either but i do now
thanks ian
PostPosted: Wed Feb 28, 2007 5:40 pm
I pulled mine out towards the inside of the window as I found this easier (Clubby) and a bit of a twist and wiggle motion as it came. Also use tape on the metalwork around the top of the window to save the paint.
PostPosted: Wed Feb 28, 2007 7:02 pm
Thanks Ian I didn't realise it had two bolts it out now :D to start masking....
Users browsing this forum: No registered users and 224 guests
