It is currently Tue Aug 19, 2025 6:15 am
 Post subject: gear shift noise
PostPosted: Mon Mar 26, 2007 9:14 pm
My Wolseley 1300 has a Mini K (or Delux) full synchro gearbox - the guy I brought it from couldn't remember which, anyway the gear lever "sizzles" and vibrates on over-run and fair drives me mad. The nooise stops if I apply pressure to the gearshift with my hand or knee (or better yet if I get a passanger to do it). Question is........ can it be fixed? If so, how?
'62 Morris 850 (Marion)
'69 Vanden Plas Princess 1300
'71 Wolseley 1300
'74 Austin 1300 Countryman
'94 XJ6 Sport 3.2
'04 Rover 75 CDTi
PostPosted: Mon Mar 26, 2007 9:24 pm
The bottom of the gear stick sits in a little $2 nylon cup. Thats where the noise is coming from, a worn away cup.
Betcha i am right !!!!
Replace the cup and see how you go. Its not a big job to take out the gear stick, replace the cup and put it all together again.
PostPosted: Mon Mar 26, 2007 9:33 pm
Like Mike says change the little nylon cup. Whack some grease around while you are there. :wink:
Deluxe = 3 syncro.
K = 4 syncro.
PostPosted: Tue Mar 27, 2007 6:39 am
A new nylon cup did nothing in mine and greasing all parts lasted about 10 minutes. I'm pretty sure on mine the noise (rattle) comes from a worn bell end lever crank and/or pin. See number 27 & 28 on the parts list here.
www.minimania.com/web/CatPage/4-21/Chap ... atalog.cfm
PostPosted: Tue Mar 27, 2007 9:20 am
If all else fails, try a rubber suspension bush on the end of the gear lever so that it bears on the selector toggle. I think a Morris 1000 lower control arm bush fits real neat once it is trimmed to size. :wink:
PostPosted: Wed Mar 28, 2007 5:10 pm
thanks all
i'll let you know how i get on after easter
'71 Wolseley 1300
'94 XJ6 Sport 3.2
'04 Rover 75 CDTi
