It is currently Tue Aug 19, 2025 3:38 am
 Post subject: Exhaust
PostPosted: Thu Apr 05, 2007 8:28 am
The rear exhaust hanger from the rear subframe.
Is it hardmounted to the subframe or is connected using one of the rubbery flexible connectors?
PostPosted: Thu Apr 05, 2007 8:38 am
I have a metal bracket and a flexible exhaust rubber connector.
PostPosted: Thu Apr 05, 2007 9:54 am
cotton reel rubber in the mid-section under the rear seat area
rectangular rubber block to hold the muffler right at the end
both with metal brackets and u-bolts :wink:
Inconspicuously Conspicuous
PostPosted: Thu Apr 05, 2007 10:01 am
that'd be it ... :lol:
PostPosted: Thu Apr 05, 2007 10:13 am
Except if you are looking at Rover Minis.
They have two rubber hangers at the tailpipe,and the exhaust system moves around.
PostPosted: Thu Apr 05, 2007 12:48 pm
Cooper S have two cotton reel mounts and a triangular (sort of) plate mounte to these. This then clamps to the pipe.
(Not specific to this, but I thought I'd throw it in...)
PostPosted: Thu Apr 05, 2007 2:03 pm
only real men dare to use tyre wire
and a few conversions:
13B Extend in a 1600
PostPosted: Thu Apr 05, 2007 2:27 pm
I think it's the other way around..
cotton reel at the end..and block in the middle of the car..? :)
PostPosted: Thu Apr 05, 2007 2:31 pm
both with metal brackets and u-bolts Wink
that'd be it ... Laughing
cotton reel at the end..and block in the middle of the car..? Smile
I agree. Every Cooper S I have seen has it this way. Cotton reel at the end..and block in the middle of the car.
PostPosted: Thu Apr 05, 2007 4:28 pm
Yeah block in the middle near the fuel pump.
PostPosted: Thu Apr 05, 2007 5:54 pm
i had a lot off problems with braking rubber mounts so mine was just one ubolt at the slip joint on the extractors and another one at the rear into the subframe no dramas didnt budge
cheers bob
1978 NUGGET GOLD 1275 LS
PostPosted: Thu Apr 05, 2007 7:41 pm
i have a dead line of july 28 to get mine going im going to kick your arse biam your a wuss cant even get a moke on the road wuss wuss wuss
PostPosted: Thu Apr 05, 2007 8:41 pm
righty O then.
My kids, 12 and 10 are the reason my project is being done. Every step of the way I am showing and teaching them that you can fix things themselves and that you dont need to vote with your credit card. So if it takes me another ten years, thats fine with me because I will have something far more valuable than a 1971 Moke, I will have spent thousands of hours with my kids.
So while I appreciate the jest in which you meant your comment, I think you may be missing the point.
:P :P :P :P :P
PostPosted: Thu Apr 05, 2007 10:19 pm
^^^^ Your kids are lucky to have you and not an X-box on the credit card and piss off type of dad.
The usual set up on Mokes is the square hanger at the front of the rear sub frame. It has two screws to the frame on the diagonal. At the rear is a single cotton reel. Most mokes have a straight exhaust as opposed to the diagonal through the rear sub frame. Certainly the late Californians do because the low-mounted rear bumper brackets are in the way of the diagonal style exhausts. That's why my RC40 sits down the middle of the sub frame but the outlet points off to one side, looking a bit dumb.
M
PostPosted: Fri Apr 06, 2007 7:01 am
I have a 4yo daughter and a 1yo son and they are just great little helpers. My daughter keeps coming out and saying can we go for a drive in it yet, then looks to see if the engine is in. She says "no engine" and goes back inside.
Users browsing this forum: No registered users and 314 guests
