It is currently Fri Jul 18, 2025 5:51 pm
Post new topic Reply to topic  [ 63 posts ]  Go to page 1, 2, 3, 4, 5  Next
 Post subject: Help! What oil!
PostPosted: Thu Mar 15, 2007 8:52 pm
Dads being using a full synthetic 15w 40. Can we use a full 10w 60 full synthetic? Or should we go to a semi 15w60?
Please help!
~First Car: 1978 Mini Clubman MERLIN~
~Current Car: 2006 Cooper S JCW Checkmate MINWAH~
PostPosted: Thu Mar 15, 2007 8:54 pm
Use anything but a synthetic oil in a Mini, i dont think the gearboxes n diff like fully synthetic stuff....
i dont think ur ment to use any synthetic oil in ur mini :?
PostPosted: Thu Mar 15, 2007 8:55 pm
hpr 30 penrite or castrol gtx2 are a good choice 8)
 Post subject: Re: Help! What oil!
PostPosted: Thu Mar 15, 2007 9:41 pm
Please help!
for a mini?
for a bmw mini? or a classic one?
for a bmw mini, check your owners manual, it will specify what oil to use.
for a classic one, you want any non synthetic 20/50
PostPosted: Thu Mar 15, 2007 9:45 pm
Penrite HPR30 for a decent older engine
HPR40 for an oil burner
Miniworx Centre 0883741299
Online BMW Mini Shop
PostPosted: Thu Mar 15, 2007 9:47 pm
also penrite 20-50 is a cheaper option
PostPosted: Thu Mar 15, 2007 9:48 pm
On an engine that isn't that old it works well
PostPosted: Thu Mar 15, 2007 10:26 pm
This space for rent
Penrite HPR30 all the way. I used to use this in all my Mini's (when I had one :shock: ) and it was great. Maintained good oil pressure in lotsa conditions, never too thick (in Melbourne's climate) so I was never worrying about stone-cold starts.
Mind you, I never did one of those laboratory tests to prove the engine was as-new after 150,000km, so what do I know.
--s
PostPosted: Thu Mar 15, 2007 10:39 pm
Give Ash some flowers Nick .
I'm another HPR30 user.
PostPosted: Fri Mar 16, 2007 7:22 am
same here, hpr 30
PostPosted: Fri Mar 16, 2007 7:24 am
Castrol Edge 25W/50 is better than HPR30 Penrite IMO, but they keep putting the price up.. :evil:
<edit> I found the Penrite sludged around the filler cap neck a bit after 1000 miles, the Castrol doesn't.
I have 3 cans ot KMX 20W/50, at less than 1/2 the price of Castrol Edge it's worth a try. I change the oil at 1500 miles anyway.
:wink:
Last edited by drmini in aust on Fri Mar 16, 2007 7:43 am, edited 1 time in total.
PostPosted: Fri Mar 16, 2007 7:32 am
I have to say my Mini has been running on the above since it was changed from Formula R. I decided the other week to try out the KMX stuff it seems to be pretty good so far. Oil pressure is slightly better as well. Btw that KMX stuff is 20w/50.
I've used Penrite before and well I hated it. but each to their own :)
PostPosted: Fri Mar 16, 2007 8:21 am
Hi guys,
Multi grade oils are fine but the narrower the grade variance, the better the brew. 15/40 is good, 10/60 is getting to wide in my opinion. The problem is difficult to make the oil so that it performs accurately over such a wide range of viscosities. Mini's were made to run on something between 30 and 40, so my advice would be to stay within that area unless you're doing something pretty out of the ordinary. I use Shell Helix Plus semi synthetic 15/40 and it works well.
Regards
Al
PostPosted: Fri Mar 16, 2007 9:32 am
Too hot in Oz for 40 grades.... except maybe in winter. :wink:
General recommendation here is 20W/50, for manual or automatic.
Users browsing this forum: No registered users and 118 guests
