It is currently Mon Aug 04, 2025 1:06 pm
 Post subject: Bleeding drum brakes
PostPosted: Fri May 04, 2007 7:21 pm
Would some very kind person post a thread in the 'How To' section of this forum about bleeding the drum brakes. Tell us the correct way to do it and point out any 'wrongs'
Is it possible to bleed only the front brakes???
Rod Image
PostPosted: Fri May 04, 2007 7:57 pm
PostPosted: Fri May 04, 2007 8:40 pm
There is a right way and definately a wrong way - if no- one as detailed this before morning the I will write a treatise.
PostPosted: Fri May 04, 2007 8:48 pm
Will you be around Sunday morn Rod? I'll come round and point you in the right direction and give you a hand if you like.
Rod.
______________________________
'63 Morris 850 (Old Secondhand CAR)
PostPosted: Sat May 05, 2007 10:33 am
Thanks for the replies guys.
Symptoms are that when I press the brake pedal, it goes almost to the floor but is solid. Let the pedal up then push again and it only goes down a very small way and again is solid. I adjusted the brakes only 2 or 3 weeks ago, so assume that there's air in the system. Air would have got in about 6 months or so back when I was replacing the front wheel bearings and had the brakes off. Bled the brakes when I put the wheels etc back on but I suppose I didn't get it all out because I've had this problem ever since then - I've adjusted the brakes 3 or 4 times now in 6 months :cry:
This is why I'm saying is there a right and wrong way to do this job.
Rod, I'd love to get a few pointers from you on Sunday morning - I'll make sure there's a cup of Jan's coffee here for you :D
Hooroo
Rod Image
PostPosted: Sat May 05, 2007 12:55 pm
If what you just said was actually true in that the peddle is solid,,, then it`s adjustment that is the problem
if the peddle is soft & spongey then there is air in the system & needs bleeding
To bleed front brakes, you will need to "UN_ADJUST" them first,,, then bleed them,,, & then "ADJUST" them back up
to un-adjust you will need to turn the adjusters opposit to the rotation of the wheels, then when udjusting them up after bleeding, you will need to turn the adjusters in the forward direction of the rotation of the wheels
to paint you all a picture to make it all make more sense-->
imagine laying under the car & turn your head so you`re looking at the backplate of the Left front wheel (passengers side) to adjust them up-->. turn both the adjusters clockwises
now looking at the right hand back plate,,, turn the adjusters anticlockwise
that is to udjust "UP" the front wheels
& obviously reverse that proceedure to "UN-Adjust"
& i`ll say it again,,, you will need to UN_ADJUST them BEFORE you bleed, Then Adjust them back up
If you have adjusted them the wrong way , then they will un-adjust themselves very very quickly & you will have a very low peddle again in no time at all
If it`s a low peddle but a solid peddle, then it`s adjustment
if it`s spongey peddle then it`s air & needs a bleed
if it`s a low & spongey peddle , then obviously you need to unadjust, then bleed, then re-adjust up
any questions????
PostPosted: Sat May 05, 2007 8:42 pm
Cya in the morning Rod. I can taste that coffee already.... :D :D
Rod.
PostPosted: Sun May 06, 2007 12:00 am
hey Miniman in Brisvegas..............that makes sense. Like I said, I have a solid pedal but it just goes down way too far. Adjust them and it's fine for a while.
I'll attack 'em in the morning - with Rod's help plus a cup of fresh brewed coffee :D
Rod Image
PostPosted: Sun May 06, 2007 5:02 pm
Amazing what some-one else sees and you miss it on your own car - the top ball joint on one side and the bottom one on the other side are worn. This will be causing excess movement/vibrations in the wheels when driving along and most likely be causing the brakes to 'un-adjust' themselves.
Anyway, I'll replace all 4 and see what happens. About time the brake fluid was replaced too - it's about 18 months to 2 years old so it needs doing.
Hooroo
Rod Image
PostPosted: Sun May 06, 2007 5:44 pm
Hmmm - have a look at the ball joints before running out and spending money. They have shims and provided the actual ball and taper is not damaged you can take out the worn shims and tighten the cups until the whole thing is very tight with fingers.
Do not grease it until after you have got the "feel" of the ball joints right. Be also aware that the bottom ball joints have a spring and the top dont.
Also take my advice, and go out and buy a thirty dollar scissor type ball joint splitter - no other type is good enough and it saves all sorts of problems. The only down side to it that the Australian vernacular "french" doesn't get as practised.
I do think that you are only taking the brake adjustment that locks the brakes - there are several more highs and flats - have the brakes well and truely locked and then back it off a turn or two to free the wheel. As Matt (theminiman) said for all other bits.
PostPosted: Sun May 06, 2007 7:31 pm
Hi Mike,
Hear what you say about the shims - guess I'll find out when I take them apart.
About the scisor type ball joint splitter, I've got one but it needs replacing so that's job number one before even thinking about shims and new ball joints.
I've adjusted up the brakes again so we'll just 'wait and see'
Hooroo
Rod Image
PostPosted: Mon May 07, 2007 1:08 pm
Hey Rod, if you like I'll pop round with the EzeeBleed ? I've done a fair bit of work on brakes over the years.
