It is currently Fri Aug 22, 2025 6:43 am
PostPosted: Fri May 11, 2007 3:32 pm
Does it just click on or glue on.
Morgs
PostPosted: Fri May 11, 2007 3:35 pm
if your talking about sliding window doors, it clicks over a rivet type stud fixed to the door. delux type,clubman type (wind ups) are a press fit. no studs involved
PostPosted: Fri May 11, 2007 3:37 pm
Mines a 65 deluxe, wind up windows.
Morgs
PostPosted: Fri May 11, 2007 3:48 pm
im pretty sure you just have to press it on really hard untill you hear it lock onto the door frame. i hear its a PITA to get the trims off
PostPosted: Fri May 11, 2007 6:31 pm
Mungral job to get off without damaging, and can be tricky to get back on.
PostPosted: Fri May 11, 2007 7:04 pm
Give Ash some flowers Nick .
Do it evenly bit by bit otherwise you may end up bending it. Be careful and use paitence.
I wish you well in your quest.
PostPosted: Fri May 11, 2007 7:53 pm
Very annoying job, scratches the paint easily. I'll think I will leave it to the panel beater.
Morgs
PostPosted: Fri May 11, 2007 7:58 pm
Pulled mine off just the other day.
Bent them like crazy, and stripped half the paint off the door.
I don't care though, I don't like the chrome round there. :D
