It is currently Mon Jul 21, 2025 12:39 pm
 Post subject: Disc Brakes weight?
PostPosted: Sat Jun 02, 2007 12:46 pm
Hi, what would a full set of disc brakes weigh, 7.5" and 8.4"? Does handling change much if using either one? (from drums)
Read that sometimes a set of adjustable arms were needed or is this only if going to a non mini disc setup?
Thanks.
Michael N
 Post subject: Re: Disc Brakes weight?
PostPosted: Sat Jun 02, 2007 1:03 pm
Thanks.
7.5" S or 8.4" late Mini brakes are a tad heavier than drums but you won't notice it.
You only really need adjustable lower arms and tiebars if using Metro swivel hubs, which have different balljoint geometry.
If using a Honda or Camira (for example) brake conversion on drum swivel hubs, the geometry is unchanged except track is wider (about same as the S setup).
Disc brakes are well worth it over drums, IMO. Whatever the cost.:wink:
PostPosted: Sat Jun 02, 2007 1:24 pm
Thanks, looking at a set of used ones from the UK and trying to work out postage, are the 7" early cooper ones any good or are they too small? Read somewhere on here that is why not to use some from the smaller Jap cars as they are only meant for low HP cars and lower speeds.
Michael N
PostPosted: Sat Jun 02, 2007 1:28 pm
I would NOT bother bring in early Cooper 7" ones. I used them years ago as I got for nix.
They are only 1/4" thick rotors when new. Can be made to work with hard pads and a servo but the rotors are too expensive now (around $150 ea??)
Also beware buying s/h S ones, unless are cheap you could spend almost new price getting them right. Ask Lillee.... :lol:
 Post subject: 7.5
PostPosted: Sat Jun 02, 2007 5:57 pm
When we send discs they weigh about 22-23kg for a 7.5" setup
Andrew
Andrew@Minisport, South Australia
Ph: 08-8177-1275
Skype: minisport.au
www.minisport.com.au
Minisport for all your mini parts
PostPosted: Sat Jun 02, 2007 10:15 pm
Thanks all. Thought a pair would be more than that.
Now to decide rebuilt or trashed.....
Michael N
PostPosted: Sun Jun 03, 2007 7:16 am
micheal i bought a clubbie the other day for the contessas and there was a set of discs on that, i have been looking for a set for a while and only paid $350 for the lot
Users browsing this forum: Bing [Bot] and 100 guests
