It is currently Mon Jul 28, 2025 7:29 pm
PostPosted: Mon Jun 25, 2007 8:42 pm
hi, my steeing has started to begain to squeak today. it starts to begain to squeak at full lock. i have heard the same noises in many other old cars, but i carn't find wats causing this problem. it's not a ginding noise but a squeak.
please help.
thanks
PostPosted: Tue Jun 26, 2007 10:50 am
could be tyres rubbing, have you greased all your steering components? because it only happens at full lock it sounds like your problem could be your tyres. best to have a mate standing outside the car looking for signs on where it may come from aswell.
PostPosted: Tue Jun 26, 2007 1:28 pm
Would the ball joints create a squeaking sound?
What condition are the wheel bearings in?
Ive had this happen to my car and noticed it would go away when the car had been drive for a little while. Doesn't happen anymore since i redid the wheel bearing and ball joints. Maybe a fluke im not sure.
PostPosted: Tue Jun 26, 2007 3:08 pm
Give Ash some flowers Nick .
Is the squeak coming from outside the car or could it be possible that it's coming from inside?
I had a squeak in my car that happened when ever I turned the steering wheel. The earth for the indicators was sqeaking as it rubbed along the collar - a light touch of WD40 and it's all good - no more squeaks.
PostPosted: Tue Jun 26, 2007 5:21 pm
hi, thanks for the replys, but it is not out side the car. its coming from the steering callor area. it might be the indicators.
PostPosted: Tue Jun 26, 2007 5:25 pm
BTW - I also found some really fine sand paper worked really well; that's if you don't want your car to smell like WD40 - I did mine over summer and had the window's down anyway.
The emery paper worked well but i could still just hear a squeak.
