It is currently Wed Jul 23, 2025 1:32 am
PostPosted: Sat Jun 30, 2007 4:10 pm
I've just replaced the rear wheel bearings on one side of my machine.
My Haynes manual says the retaining nut torque should be 81Nm / 60lbft, but that feels REALLY tight. Is that the right torque???
The bearings I found when I dismantled the hub were ball rollers with a spacer between.
The bearing kit I have is just two taper rollers with no spacer, but the inner races are extended to take up the gap the spacer filled before.
Am I doing something wrong?
_____________________________________
1966 Cooper S (in lots of bits)
PostPosted: Sat Jun 30, 2007 4:30 pm
yes the torque is correct.
The tapered rollers when assembled in an unworn hub have about .001" preload, they should feel a little tight when torqued up to spec, but not jerky when turned by hand. :wink:
PostPosted: Sat Jun 30, 2007 6:34 pm
And as a side note, a lot of torque wrenches dont work backwards (left hand thread), so don't overtighten it! :D
 Post subject: wrench
PostPosted: Sun Jul 01, 2007 2:37 am
I had the wrench problem yesterday. Its weird its got a left and right switch but doesnt click.I just tightened it up then backed it of until it would move at roughly the same time as it clicked
blokeinamoke wrote:
PostPosted: Sun Jul 01, 2007 1:35 pm
Cool. Thanks for that chaps.
The hub does spin smoothly, but it seemed too tight for a bearing. It'll run in, I guess.
Regards
Jamie
