It is currently Fri Jul 18, 2025 1:41 pm
 Post subject: Cooper Questions
PostPosted: Sun Sep 02, 2007 2:10 pm
Some 997 Cooper questions :
Body colours are Saxon Green roof with Osmond Green body , what colour should seats and trim be , and what pattern should be on door cards ??
Is fuel pump mechanical or electric ??
Does engine number on ID Plate have capital A in it or small a , as in Cooper S ??
1965 Morris 850
1966 Morris Mini Minor
1967 Morris Cooper 'S'
1977 Leyland LS
PostPosted: Sun Sep 02, 2007 2:15 pm
If 'graham in aus' doesn't see this thread, PM him.
He owns an Osmond/Saxon 997, and I believe its quite original.
Hope that is of some help to you.
PostPosted: Sun Sep 02, 2007 2:22 pm
Definitely electric pump. the original cooper 997 and 998 engines did not have the hole in the back of the engine to accept a mechanical pump.
Not sure on the trim, but would hazard a guess at almond green. Best wait for Graham.
PostPosted: Sun Sep 02, 2007 2:51 pm
No pattern on door trim. Just a sheet of vinyl with padding attached to back a la Morris 850. Trim colour is light green. Carpets a green short loop pile with brown flecks. Will post photos of interior etc. Note: door trim has had other material stuck on it sometime in the past hence the glue stains/wrong colour. Oh, and capital A on ID plate and elec fuel pump.
PostPosted: Sun Sep 02, 2007 3:44 pm
Hey Wild willy,
Would you mind posting a pic or two of your A7 in the other makes forum? I assume it is yours as it is in the background of your Cooper pic.
I love Austin Sevens and would like to see some pics of yours.
Matt
PostPosted: Sun Sep 02, 2007 4:42 pm
Thanks for the info everyone .... and thx for the pics wild_willy , do the seats have the rough finish on them , same as 850 ?? , and does the block have the cutout for the mechanical fuel pump , same as the 850 also ??
1965 Morris 850
1977 Leyland LS
PostPosted: Sun Sep 02, 2007 4:52 pm
The 997 Cooper block has no provision for a fuel pump. The original seats were covered in a good quality vinyl unlike the 850 which had a patterned (checkered or lizard skin) cheaper vinyl material. The seats in the photo are the original style.
PostPosted: Mon Sep 03, 2007 1:06 pm
Ooooh how did I miss this one!
Nice car wild willy! original carpet too! I only have a small section of mine :cry:
I agree with all that Wild willy says, he's spot on!
Oh, exept the fuel pump hole, very early 997 blocks had a fuel pump hole and 1000 'cast' into back of block, as opposed to no pump hole and 1000 tag. There are also some extra 'bosses' on the front of the block, I think these blocks coul relate to the "Formula Junior" blocks, I'm investigating further!
I only discovered this the other day looking at a couple of my early numbered engines! :lol:
Sir Alec! we are not worthy!
PostPosted: Mon Sep 03, 2007 2:31 pm
You've got a menagerie of early 997 engines? That would be an eclectic collection!
PostPosted: Mon Sep 03, 2007 5:09 pm
That is a very interesting observation Graham. I'll put that in the data base. I have another very early 1962 Cooper (body around the first 200 produced in Aus) but unfortunately as is the case with many 997's no original engine. It also uses the heater system with the blower mounted on the right inner guard. Interestingly this car seems to be rally/race prepared by the factory with a very neat hole in the inner guard to access the flywheel nut and two speed nuts fitted for a quick release grill (to neat to be done by any others I would think) and a hole above the right indicator lamp which may have been for auxilliary lamps wiring.
PostPosted: Mon Sep 03, 2007 6:37 pm
Yes mine has the fuel pump hole and 1000 cast into back of block . The car number is in the early 2200's , would this be late 1963 ?? Engine number is in low 20,000's ie 203 - -
1965 Morris 850
1977 Leyland LS
PostPosted: Tue Sep 04, 2007 12:23 am
The ones I have are earlier than that one AJ, yours I would say is a 63 car, does it have the UK type number on the chassis plate something like 366--- ? or just the Aus number like 22-- ?
Thanks for sharing! :lol:
PostPosted: Tue Sep 04, 2007 8:54 am
Yeah just the Aus number graham 22 - -
1965 Morris 850
1977 Leyland LS
PostPosted: Sat Sep 08, 2007 10:35 am
What type of aircleaners do 997 Cooper have ?? and what is wheel rim size and type ??
1965 Morris 850
1977 Leyland LS
PostPosted: Sat Sep 08, 2007 11:30 am
Airfilters are pancake type with a coarse mesh painted hammer tone grey. I can send u photos if this helps. Wheels are standard mini 41/2 J, painted black fitted with Cooper wheel trims
Hope this helps
Users browsing this forum: Bing [Bot] and 102 guests
