It is currently Fri Aug 15, 2025 1:45 pm
 Post subject: Mk1 master cylinders
PostPosted: Mon Sep 17, 2007 2:10 pm
Hi guys,
What is the deal with Mk1 brake master cylinders? Some have an identifying ring at the base and some don't. I used to know but cannot recall right now.
Regards
Al
PostPosted: Mon Sep 17, 2007 2:22 pm
The MCs with the ring around them had a different main seal (not a plain cup)- it fitted over the piston similar to the bottom seal. :wink:
PostPosted: Mon Sep 17, 2007 2:29 pm
Hi Kev,
Thanks for that. I seem to recall there was a change date, any ideas?
Al
PostPosted: Mon Sep 17, 2007 4:42 pm
Sorry, no idea- you need a dude with a parts book. Morris 1100.. where are you??? :lol:
PostPosted: Mon Sep 17, 2007 6:33 pm
I have just looked through my parts books and I can't find a changover date.
I have a 69 Mini parts book (just before the change from Deluxe to K) and a last edition Morris 1100 parts book from about 72 and neither of them mentions a change.
Karcraft shows both part numbers in their catalogue but no date.
Ring = two "ring" seals. Part number BAU1247
No Ring = one "ring" and one "cup" seal. Part number 50957
PostPosted: Mon Sep 17, 2007 7:09 pm
Can anyone describe the 'ring' a little better? I have a number of MC's here, but the only differences I see are in the top where the brake line union screws in.
PostPosted: Mon Sep 17, 2007 7:12 pm
The groove varies, sometimes it is on the bottom part below the reservoir, other times it is on the reservoir itself. It is basically a groove that runs all the way around the master cylinder. Sometimes it's hard to see if the m/c is dirty.
PostPosted: Mon Sep 17, 2007 7:21 pm
Do you have any that look like these?
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
PostPosted: Mon Sep 17, 2007 7:27 pm
This should explain it better.
PostPosted: Mon Sep 17, 2007 7:37 pm
Sorry Timbo, none like that one I am afraid...I had a look last time you said you were hunting for them..on a bright note though, I still have a rivetted 3.5 inch rim in careful storage around the back!
I had a look through the MC's again, one has a ring around the taper down at the top of the MC. it is quite distinct having been cut in by a lathe. The bore is .75 and (obviously later down the track ) stainless steel lined.
PostPosted: Mon Sep 17, 2007 9:00 pm
Oops sorry, I'll get on to that this week!
1955 BSA C11G
1969 Triumph TR6R
PostPosted: Mon Sep 17, 2007 9:01 pm
No stress, it's doing no harm around the back.
PostPosted: Tue Sep 18, 2007 9:39 am
Hi folks,
Thanks for your help, I'll keep trying to find a change date and report if I do.
Regards
Al
Users browsing this forum: No registered users and 244 guests
