It is currently Fri Jul 18, 2025 10:32 am
PostPosted: Tue Dec 21, 2004 8:49 pm
went to take the slidemonster for a run tonight and when i pulled the garage door....... i was greeted by an ever increasing puddle of hydro fluid :shock: :evil: . I must be a slow leak due to the fact that no fluid has found it's way onto the paintwork, just slowly dripping from the valve head itself.
Am i correct in assuming the valve is shot and needs to be replaced??? or is the problem something more deepseated???
Also, what is the procedure for replacing, i'm gathering that it is empty that side out (this being the passenger's side in my case) remove the valve and replace or recondition it, then refit and pump it back up................
Merry Christmas Steve, from your mini.... Slidey :x
I got nuthin......................
PostPosted: Tue Dec 21, 2004 9:06 pm
Steve,
They are just a Schrader tyre valve. Push it in with the valve cap until all pressure is gone, unscrew it and immediately fit a new one, tight- pump back up. Helps if you have a hydro pump.... :wink:
No need to vacuum it, as you haven't disconnected any pipes etc so air hasn't got in.
PostPosted: Tue Dec 21, 2004 9:18 pm
Sweet doc..... cheers for the info. I hope Matt is back from mountain bike riding.... cos imma comin callin in the morning 8)
PostPosted: Tue Dec 21, 2004 9:33 pm
Mate sorry to here more bad luck with the suspention....Slidey is just showing she want's attention again not just photo's :?
PostPosted: Tue Dec 21, 2004 9:42 pm
very true gaf :oops:
PostPosted: Tue Dec 21, 2004 9:45 pm
hmm
the matic is also doing a wee on my garage floor,
its also green, but from the radiator
do you have a hydro pump and fluid steve? karkraft in sydney does
just ask matt, he's your local mini hero
Inconspicuously Conspicuous
He or She :?: Slidey that is
PostPosted: Wed Dec 22, 2004 2:21 pm
Slidey is a he.............
Going to Jack Read's (Matt's dad) of Readspeed in the morning to get the valve looked at and get the hydro re-filled........ so hopefully the problem is solved :o
Users browsing this forum: Bing [Bot] and 86 guests
