It is currently Fri Jul 18, 2025 5:18 pm
 Post subject: Bloody Auxilary Spring!
PostPosted: Wed Dec 29, 2004 4:26 pm
:cry:
Is there any easy way to disconnect the auxilary spring for removing the rear subframe?
Can they be disconnected at the top rather or do they have to be disconnected at the radius arm?
[Maverick] 1971 Mini K
PostPosted: Wed Dec 29, 2004 4:29 pm
Undo the tops, leave them on the arms.. :lol:
PostPosted: Wed Dec 29, 2004 4:34 pm
:lol: ...sweet
I was trying to do that though and the bloody nylon nuts or whatever they are just kept free rotating.
PostPosted: Wed Dec 29, 2004 7:31 pm
2 man job.
You need to jam the `bolt' that's inside the spring. Stick a thin screwdriver in thru the top of spring. :wink:
PostPosted: Wed Dec 29, 2004 7:45 pm
2 man job.
That would explain it...i was trying to do the same myself but it was impossible. Im not that flexible :lol:
cheers Doc
PostPosted: Thu Dec 30, 2004 1:19 pm
Tried doing the screwdriver method today....its not working.
We even tried holding the bolt with a pair of vice grips but its no use.
I think im going to take off the hub and try and get to the split pin. I have a problem there to though. Ive undone all seen bolts except It seems there is a dust cap on the hub which appears to have been there since the jurassic period which im guessing has some nut behind it. Any tips on getting the mofo off?
PostPosted: Thu Dec 30, 2004 1:30 pm
Just get the 4" angle grinder, and cut the nut off then. Not worth stuffing about with. :lol:
PostPosted: Thu Dec 30, 2004 1:32 pm
haha...sweet. :lol:
Im guessing your talkign about the spring nut then?
PostPosted: Thu Dec 30, 2004 2:08 pm
MiniK wrote:
haha...sweet. :lol:
Yeah,, the one in the boot you can't get off?
Top of spring..!
Then just lay the spring down horizontal and it'll slide off the bottom. :wink:
PostPosted: Thu Dec 30, 2004 2:18 pm
Thats the one....
Im loading the grinder as we speak :lol:
PostPosted: Thu Dec 30, 2004 4:56 pm
That did the trick... :lol:
Kind off cut off a bit of the stud but oh well 8)
PostPosted: Thu Dec 30, 2004 5:13 pm
You're not gonna use them anyway. :lol:
PostPosted: Thu Dec 30, 2004 7:09 pm
MiniK, Are you getting rid of the hydro? Because I am after a complete set up.
PostPosted: Thu Dec 30, 2004 7:14 pm
Join the queue... I got 1st dibs! :P
PostPosted: Thu Dec 30, 2004 7:36 pm
I outrank you! I need mine for a Cooper S! (I have the bags just need the rest!)
