It is currently Tue Jul 22, 2025 6:56 am
PostPosted: Thu Nov 22, 2007 7:44 pm
Milatsmadmini
ok so evryone knows the new Golf GT (the turbo+supercharged beast!), just curious if that would be possible to do to say an 1100 motor??
PostPosted: Thu Nov 22, 2007 7:45 pm
wat...
Mearcat wrote:
PostPosted: Thu Nov 22, 2007 7:55 pm
Slow-Po
It's not as simple as working out how to bolt the two onto the engine. VW has spent millions getting the set up to work effectively.
PostPosted: Thu Nov 22, 2007 8:24 pm
The way I imagin it is a "medium" sized supercharger to provibe boost from idle till the time the "big" turbo starts to boost. Obviously it is more complex than that but if I had the time and money that's where I'd start.
PostPosted: Thu Nov 22, 2007 8:36 pm
I cant see any reason why not but it would be a tight fit. Alot of people do that to toyota levins and mr2s with 4AGZE engines which have a factory sc12 super charger they then fit a turbo most use a mitsubishi TDO4 . The system is set up so the super charger works at low engine rpm and vehicle speed and as engine rpm increases the super charger switches off taking load off crank and by that time the turbo is spooling fast enough for higher rpm power :wink:
PostPosted: Thu Nov 22, 2007 9:39 pm
i guess you'd only do it for wank and bling factor :)
PostPosted: Thu Nov 22, 2007 9:52 pm
Two different 'chargers to me would mean twice the gearbox failure.
When a blower, or a turbo Mini makes plenty of grunt there is really no need to go fruther, but by all means if you want to, go for it, have some fun!
Or "bolt" a Golf GT motor in, probably easier! :lol:
PostPosted: Thu Nov 22, 2007 10:00 pm
the output figures of twin chargers on the 4agze have not given any amazing power figures, and im not sure about times. but i think the tuning and setup would be very involved and hard to get exactly right without serious money for an end result that would be no better than just a turbo. but yeah, its most definitely bling factor +10. i know nothing of the golf setup though
PostPosted: Thu Nov 22, 2007 10:23 pm
bollocks, they just copied Nissan - Nissan March (Micra), factory 930cc with a supercharger and a turbo - 10 years ago
PostPosted: Thu Nov 22, 2007 10:46 pm
and Lancia won the Rallye Group B world championship, in 1986 i think, with such a set up in a Delta S4, 2000ccm, 480 and more HP
Rover 214 atm ....
PostPosted: Fri Nov 23, 2007 6:38 am
They came out in the super march in 1988, nearly 20 years ago :D
1974 Moke - 998cc
PostPosted: Fri Nov 23, 2007 9:43 am
jeez, I'm getting old... I knew it was in the late 80's, which equated to 10 years ago :roll:
PostPosted: Fri Nov 23, 2007 10:42 am
Pardon the pun but it's a pipe dream, literally.
Not saying it's not possible, but probably not worth the effort. I think you can get an A series to it's mechanical limit with a single turbo (and not a very large one at that).
PostPosted: Fri Nov 23, 2007 11:32 am
And why do it to an 1100 motor ???? It may end up going like sting and lighting up the tyres but...... You need it to stop as quickly as it goes (drums wont do that) and you need the mechanicals to stand up to extra power.
The majority of people who put big power motors in also put in the corresponding drive lines and have the whole thing engineered as they go so that its safe for everyone around when its on the road.
There are some very quick A series motored minis around but when you talk to the owners they have either spend big money repairing the failures and mistakes as they went or the spend slightly less big money by having it done properly the first time. Choose your poison :lol:
Mike
PostPosted: Fri Nov 23, 2007 12:22 pm
so why haven't you done it yet?
