It is currently Tue Aug 12, 2025 8:35 pm
PostPosted: Sat Dec 08, 2007 1:24 pm
How do I remove this gear?
PostPosted: Sat Dec 08, 2007 1:28 pm
Take the primary gear cover (in the picture) cover off and slide the gear off the crank.
Also I believe you can pull the primary gear through the primary gear cover by removing the seal around it and then pulling it through.
PostPosted: Sat Dec 08, 2007 1:31 pm
If I pull the flywheel housing off won't oil go everywhere?
PostPosted: Sat Dec 08, 2007 1:42 pm
Yeah, a lot of oil. You will need to drain the sump. You will also need a replacement gasket and seal.
What are you trying to do anyway?
PostPosted: Sat Dec 08, 2007 2:11 pm
I'm just wanting to remove that gear so I can gt some measurements for this project http://www.ausmini.com/forums/viewtopic.php?t=38546
PostPosted: Sat Dec 08, 2007 3:05 pm
Geez.... Good luck with that one mate... Angle grinding gearboxes.....eeeek..
Users browsing this forum: No registered users and 265 guests
