It is currently Tue Jul 29, 2025 3:03 am
PostPosted: Wed Dec 19, 2007 12:57 pm
Milatsmadmini
hey all,
started pulling apart my 1098 this morning and came across the original oil filter, as pretty as it is.... what is the easiest way to convert to the more modern screw on canister type oil filter?
cheers,
matt
PostPosted: Wed Dec 19, 2007 1:13 pm
Just buy the screw on adapter thingy and a filter.
Bolts straight on.
:D
PostPosted: Wed Dec 19, 2007 1:15 pm
All you need is the spin on head for the engine.
Minisport sell a kit...
http://minisport.com.au/prod1003.htm
PostPosted: Wed Dec 19, 2007 1:16 pm
Milatsmadmini
cheers guys
PostPosted: Wed Dec 19, 2007 4:24 pm
The studs it uses to bolt on the screw on are a different length. Make sure you get those as well as the appropriate new gasket.
The oil line bolts straight up but be careful with it. Its a thin metal material and its kinks and breaks easily. Get it in position and tighten it down at either end as you go.
PostPosted: Wed Dec 19, 2007 4:45 pm
Bugger the studs, I just use 2 3/8 UNC starter bolts.. perfect. :wink:
