It is currently Mon Aug 11, 2025 10:27 pm
 Post subject: mini heads
PostPosted: Sun Dec 23, 2007 9:41 pm
Milatsmadmini
ok, so yes, i still am quiet the noob....
just curious with wats the difference with heads, i have a 1098 engine but i see people throwing in 12g202 and 12g295 and i have no idea wats the deal-io here.....
please help..... dont laugh.... lol...
another thing, is it possible to convert from leaded to unleaded fuel using the stock head?
cheers,
matt
PostPosted: Sun Dec 23, 2007 10:14 pm
yes you can have unleaded seats fitted to your current head.
blokeinamoke wrote:
PostPosted: Mon Dec 24, 2007 6:27 am
A standard 1098 has a 12G202 head. This is also the head fitted to most 997 Coopers and mk2 Sprites. It has square intake ports and 1.156" inlet valves.
a 12G295 head was fitted to 998 Cooper, Mk2A Sprite and MG1100 (UK). It has bigger square ports, 1.219" inlet valves, and a much better chamber shape. It's the best smallbore head BMC made, but chambers are too big (giving a low C/R) unless running flat top pistons.
A 202 head can be modified to perform just as well or better than a 295 one. See Russell Engineering in Sydney.
To see which head you have, remove rocker cover and look for numbers CAST on top of head, under the rocker gear.
PostPosted: Mon Dec 24, 2007 10:22 am
Milatsmadmini
cheers doc!
you have yourself a very merry christmas!
Users browsing this forum: 1071 S and 266 guests
