It is currently Mon Aug 11, 2025 7:39 pm
 Post subject: Head work
PostPosted: Mon Dec 24, 2007 7:33 am
Hi all. Just out of curiosity, how much can you modified a standard 998 A+? And is the price of modification is worth the money. Or are you better getting a different head?
Any feedback appreciated...
Cheers, Louis
PostPosted: Mon Dec 24, 2007 9:10 am
If you are wanting to mod a head, i'd get hold of a 12G202 (off an 1100) and get that done. You wont be able to drive your car while your current head is off, so get another head done!
PostPosted: Mon Dec 24, 2007 9:19 am
Although ports are smaller inside, GR can mod an A+ 998 head as good as he can a 202 or 295, it just takes a bit longer and costs a bit more $$$. :wink:
PostPosted: Mon Dec 24, 2007 9:45 am
you can probly do alot of the work yourself. Its really time consuming but if you stay "conservative" you wont break through anywhere.
I just did an 12g202, it cost me about $500 bucks.
Is the chamber volume of a 998 A+ the same as a 12g202?
if it is go easy on the chamber mods, I had some dramas getting enough compression. I ended up having to mill the tops of my pistons to reduce some of the dish then get the block decked 63 thou. I ended up sitting the pistons out of the block by about 5 thou. I probly have about 10-1 now.
blokeinamoke wrote:
PostPosted: Mon Dec 24, 2007 11:10 am
998 head chambers are 24.5cc, a 202 head is 26.1.
PostPosted: Mon Dec 24, 2007 12:29 pm
Ok so you can take little more off.
blokeinamoke wrote:
Users browsing this forum: Bing [Bot] and 182 guests
