It is currently Wed Aug 13, 2025 7:15 pm
Post new topic Reply to topic  [ 30 posts ]  Go to page 1, 2  Next
PostPosted: Tue Oct 23, 2007 5:39 am
Any followers of the Moke forum - please dont yawn, but hete is some info on my project to date:
Some of my parts
Aisin AMR 300 Super charger
Metro turbo carby - I had it re kitted
Turbo carb plenum.
Blow off valve
Blower Mounted
Intercooler Mounted
Image[url]
Carb in place - I cad to cut in to the fire wall to get it in - bugger.
I have had the set up running - no pipes connected. It screams.
I run the beast up on a dyno before I started the fit up - a massive 30.2 HP - I will be interested to see what I get once connected up.
I am NOT expecting a massive improvement - The motor is stock, with extractors and RC40 exhaust.[/url]
It's not a mini, but still a bloody lot of fun! (and keeps me poor)
PostPosted: Tue Oct 23, 2007 7:19 am
Thats going be a mightty powerful Barbeque
but seriously - looks interesting - I look forward to hearing how the finished product goes.
PostPosted: Tue Oct 23, 2007 7:30 am
Your are a bad man bloke - the BBQ has a turbo on it already - be silly to blow it as well............??????
PostPosted: Tue Oct 23, 2007 7:42 am
what is the blower from - its quite small
PostPosted: Tue Oct 23, 2007 8:05 am
They're from a 660cc twin cam multivalve Subaru engine , they come out of one of the Kei (sp?) class cars in Japan , a Subaru Rex (not relation to a WRX "rex" ...) .
PostPosted: Tue Oct 23, 2007 9:18 am
Yep, also found on the (import) Subaru Vivio. Theres also a slightly (very slightly) bigger AMR500 available (from the Nissan March, I think).
They (the AMR300) work quite well on 998's (I used to have one on my Moke before going to the Ben Aford/SC12 setup).
Never did have mine dyno'd with the AMR300 but it gave a driving 'feel' roughly the same as a standard 1275 (that vague enough for ya? :D )
I used a tiny intercooler (stock Silvia one, I think) - with an intercooler as big as the one you have, it might be a bit laggy (big volume to fill).
Still, for the dollars spent (much cheaper than SC12 setup), it's an excellent mod.
PostPosted: Tue Oct 23, 2007 4:20 pm
hey man,
how much did the set up cost u if u dont mind me asking?
would it bolt on to my 998 leyland:-)
heheh
PostPosted: Tue Oct 23, 2007 5:39 pm
so far:
$220 for blower
$119 for intercooler
$29 fuel press regulator
$50 plenum
$6.50 for belt
$35 for blow off valve
$100 for carby
$200 to get carby re built
$70 for boost gauge.
8 hrs so far to fit up.
plumbing still to go - approx $150?
All up under a grand.
I have done it more as a project to see if I could work out how to set up something like this.
PostPosted: Wed Oct 24, 2007 7:13 pm
That's looking good Andy, you've passed my level of compleation in the SC project. Bring it on a run some time and gis a good look :D
PM sent
PostPosted: Thu Oct 25, 2007 4:57 pm
Is the blow off valve being used as a 'back fire release valve'?
As with the SC setup it won't vrrroooom pssst.
However, on 92's SC12 kit there is a spring loaded valve which releases the burnt fuel air mix out in the event of a back fire (which do occur, I know!)
It looks like a good setup though! Should be fun!
PostPosted: Thu Oct 25, 2007 5:09 pm
This is a blow though setup, remember. . . .it'll vroom-psst all you want :)
PostPosted: Thu Oct 25, 2007 5:43 pm
True, but after you take your foot off in a turbo car, the turbo, won't slow down imediately, it'll spin and boost for a bit longer. This fills up the plenum and becasue the engine can't take the air it slows down the turbine. So when you put for foot back down, eg. in a gearchange, there will be lag as the turbo needs to get spinning again.
On a supercharged car the charger will stop boosting the moment you take your foot off the accelerator.
My vote is for vrrooommm.....vrrooom, no psssst.
But i might be slightly wrong, or have the complete wrong idea, either way, feel free to correct me. :)
PostPosted: Thu Oct 25, 2007 5:48 pm
The supercharger is still turning when you change gears. . .so it's still producing boost.
When the throttle is shut, the pressure is higher on the plenum side of the carb than on the engine side, so the BOV opens and. . .psst!
I got a lot of odd looks due to the very japanese-sounding BOV noises coming from my Moke when it had a blow though supercharger install on it. . .
PostPosted: Thu Oct 25, 2007 6:35 pm
Ah ok, fair enough.
PostPosted: Thu Oct 25, 2007 6:44 pm
Broom, Psst, Broom, Psst. :D :D
Users browsing this forum: No registered users and 267 guests
