It is currently Tue Jul 29, 2025 6:11 pm
 Post subject: stone guards
PostPosted: Fri Dec 28, 2007 11:26 am
i bought myself a new set of stainless steel stone guards for my head lights and i have no idea on how to fit them properly could someone fill me in on how to fit them to my head lights i have tried and i must be doing something wrong :oops: :oops:
cheers damian
PostPosted: Fri Dec 28, 2007 11:29 am
Normally you just take the chrome ring off the front of the light , put the guard inside the chrome ring and put it back on , unless there are some other mounting lugs or anything there for it ?
PostPosted: Fri Dec 28, 2007 5:21 pm
i have the guards with the clips ...
http://cgi.ebay.com.au/ws/eBayISAPI.dll ... Y.m238.lVI
like these
PostPosted: Fri Dec 28, 2007 7:24 pm
Random I just did mine today!!!!!
This is how I did mine.
Step1: remove outer headlight ring (pull up and out to remove)
Step2: undo the 3 inner retaining ring screws (not all together or the light will fall out) and screw back in with the new clip.
Step3: put back outer headlight ring, and clip on guards. I found that have the mesh pattern on an angle worked best. Just a matter of rotating round and finding the magic combo that lets all 3 clips go through. A little bit of bending the clips out to make it nice and tight.
Step 4: check out your new rally look, ha!
PostPosted: Fri Dec 28, 2007 7:25 pm
I like the look of stone guards - period rally look
PostPosted: Fri Dec 28, 2007 7:35 pm
OK , different to mine , mine have a lip around the edge that sits under the chrome ring .
PostPosted: Sun Dec 30, 2007 7:09 am
by the looks of those ones they'd fit onto clubbies aswell, is that right?
