It is currently Sat Jul 19, 2025 9:42 am
 Post subject: Gearbox question?
PostPosted: Sun Mar 09, 2008 10:05 am
Hi All,
Can anyone please identify this Gearbox number for me: 22G68.
Which model is it from & when was it used (which era)?
Any other detail would be appreciated (synchro, etc).
It also has a serial number 5/22013. Will that give me any info?
Thanks.
63 Morris Cooper.
UK Mini van.
PostPosted: Sun Mar 09, 2008 10:13 am
From what i can gather it is a 850 magic wand type with baulk rings and is a 3 synchromesh..cheers!!
They also came as a remote control type...
PostPosted: Sun Mar 09, 2008 10:14 am
It's a 3 synchro, baulk ring synchro.
Can be either A or B form gears.
used on 850, 998, 997 and 998 Cooper, remote shift or magic wand. :wink:
PostPosted: Sun Mar 09, 2008 10:27 am
Thanks everybody.
So this could be the correct gearbox for my 997 Cooper? drmini what are A OR B form gears?
63 Morris Cooper.
UK Mini van.
PostPosted: Sun Mar 09, 2008 10:37 am
Doc will tell you more than me but i think its to do with the angles of the teeth on the laygear...at what angle they mesh...
PostPosted: Sun Mar 09, 2008 11:19 am
The tooth form was changed around 1964, B form are stronger- and were used on all A series Mini boxes thereafter. I think their `pressure angle' is different.
To see if the box actually has Cooper gears in it, count the teeth on 3rd gear, should be 24T. (23T was used on 850).
A Cooper 997 laygear (A form) should be p/no 22G76, or 22G197.
Many parts for these old boxes are now NLA, so good luck... :wink:
B type gears can be fitted into these boxes if you fit the whole geartrain.
PostPosted: Sun Mar 09, 2008 1:18 pm
Great, thanks Doc my cars a 63 & the gearbox is joined to a van motor at the moment. When I get a chance I will check it out. Good info thanks again.
63 Morris Cooper.
UK Mini van.
