It is currently Mon Jul 21, 2025 11:50 am
 Post subject: vent window locks
PostPosted: Thu May 29, 2008 2:47 pm
howdy all
any suggestions for retensioning the little vent window locks once they''ve lost their urge?
can they be serviced?
replaced?
are new ones available?
'62 Morris 850 (Marion)
'69 Vanden Plas Princess 1300
'71 Wolseley 1300
'74 Austin 1300 Countryman
'94 XJ6 Sport 3.2
'04 Rover 75 CDTi
PostPosted: Thu May 29, 2008 3:12 pm
Front or rear?
Front has a little spring and a roll pin in it, however it is not an easy thing to replace as they go in from one side only - making it difficult to drift it out.
In saying that, Morris 1100 (etc) have different quarter windows to Minis so the lever may be different.
PostPosted: Thu May 29, 2008 8:03 pm
If you are talking about the front quarter vents, there is a 3/8" nut on the bottom pivot that can be tightened to take up the slack and tension the flat washers that are there for this purpose. This will then give you the tension needed to keep the windows open.
1964 998 Cooper , 1968 Morris 1100
PostPosted: Thu May 29, 2008 8:19 pm
I think Kevan is talking about the front 1/4 vent window latch... sounds like Anto has the fix there - must be a pain in the arse job tho
PostPosted: Thu May 29, 2008 8:23 pm
Yep they're the ones I meant Simon (btw thanks for getting my name right!)
sounds like a right pain of a job!
'71 Wolseley 1300
'94 XJ6 Sport 3.2
'04 Rover 75 CDTi
PostPosted: Thu May 29, 2008 8:33 pm
Great question and about time someone asked but lucky enought I don't need to worry about it at the moment but we all know we will at some time :roll:
