It is currently Fri Jul 18, 2025 8:13 pm
 Post subject: SU carb info needed
PostPosted: Fri Mar 18, 2005 10:56 am
How can you tell what size your su is? by numbers on it? measure it? i need to know so i can get a rebuild kit, or can you buy individual bits? im after a needle and seat......
Any info would be appreciated
Just remember, wherever you go..........................there you are
PostPosted: Fri Mar 18, 2005 11:11 am
Easily distinguished by the appearence of the carbie itself.
If the mount on the manifold has its studs on a 45deg angle, then it is a 1.5" SU. If the studs are vertical, then it's a 1.25".
PostPosted: Fri Mar 18, 2005 11:15 am
what engine size is it ? if its an 1100 most likely a 1.25 if 998 most likely 1.5 ( stupid i know )
lookin for another clubby
PostPosted: Fri Mar 18, 2005 11:24 am
Fuel Miser rebuild kit `SU-750' from Repco etc, fits both HS2 & HS4 carbs.
I just got 2 of 'em off MiniK to do my twin HS4s. :D
Kit includes needle & seat, all gaskets, & new jet assembly.
Around $20. :wink:
PostPosted: Fri Mar 18, 2005 11:28 am
I believe its the 998cc engine number starts off 10ytah if that means anything
PostPosted: Fri Mar 18, 2005 11:32 am
That engine # is a 1098.
It would have had a 1.25" (HS2) originally but these days many have been fitted wit 1.5" (HS4) off a 998 Clubbie..
Kit I listed above will fit both. :wink:
PostPosted: Fri Mar 18, 2005 11:35 am
Thanks heaps mate that cleared it right up for me :)
PostPosted: Fri Mar 18, 2005 12:39 pm
what exactly do you mean? i just looked at it and from a birds eye view its bolted on by 2 bolts and the top bolt is on the left hand side and the bottom bolt is right hand side underneath the throttle linkage,
PostPosted: Fri Mar 18, 2005 12:42 pm
OK... if the bolts were above one another it would be an HS2- but yours are diagonal pattern so it's an HS4 (1.5"). :wink:
PostPosted: Fri Mar 18, 2005 12:45 pm
Cheers mate :)
PostPosted: Fri Mar 18, 2005 4:13 pm
Exactally what I said! :lol: :lol:
