It is currently Sat Aug 02, 2025 9:51 pm
PostPosted: Mon May 05, 2008 2:04 pm
Has anyone seen or heard or got any Cosmic 12" rims/wheels to suit a mini?? if so please let me know
Thanks
Scott
PostPosted: Mon May 05, 2008 4:55 pm
i have seen them on a Hillman Imp many many years ago, they were 5.5 x 12s so they did exist
Jon
PostPosted: Mon May 05, 2008 4:59 pm
I have seen a lot of Cosmics to suit a Morris 1100 stud pattern. (and if anyone has a spare set I would like them! 8) )
PostPosted: Mon May 05, 2008 5:04 pm
Forum Graffiti
Fancy that, I was going to PM you Morris 1100. Can you tell me what PCD a Morris 1100 is? Also do you know what Tyre they had, I think it's 145/?/R12
PostPosted: Mon May 05, 2008 5:24 pm
The Morris 1100 pcd is 4½" as opposed to the Mini 4"
The tyres are 155/80R12. That is the closest tyre size to the original 5.50x12 crossplies. I run Hankook tyres on mine. :wink:
PostPosted: Mon May 05, 2008 5:49 pm
does anyone know if the morris 1100 drive flanges work in mini hubs at all?
1974 Moke - 998cc
PostPosted: Mon May 05, 2008 5:51 pm
Forum Graffiti
<EDIT> Have no idea what I was on about... :roll:
Last edited by spraycanmansam on Fri May 09, 2008 8:02 pm, edited 1 time in total.
PostPosted: Mon May 05, 2008 5:53 pm
The Cooper S uses the Morris 1100 CV joint so I would imagine that it would work.
I have only ever fitted the Mini flange to a Morris 1100 hub.
PostPosted: Mon May 05, 2008 5:58 pm
So they are around.....but does anyone have any they would like to part company with :?: :?: anyone??
PostPosted: Mon May 05, 2008 6:53 pm
Thanks for that.
So if i was to get a couple of morris 1100 drive flanges i could run them on mini hubs and redrill the flange for say 4x108mm pcd. mmmmm something to look into i think, im trying to run 4x108 wheel on my mini and seeing what options ill have.
The rears maybe a problem unless the entire flange,drum,backing plate would fit a mini swing arm.
1974 Moke - 998cc
PostPosted: Tue May 06, 2008 10:08 am
look on ebay UK, i recon i seen them over there last year.
Check mini world ads too, i think its Huddersfield spares?? they sell a variety of new and second hand wheels too.
PostPosted: Tue May 06, 2008 11:48 am
thanks chopchop
PostPosted: Tue May 06, 2008 4:37 pm
Speaking of re-drilling drive flanges, has anyone had a mini flange redrilled to 4 x 100 PCD?
I had a look and figured if you used larger diameter 12mm studs you could basically drill out the existing holes larger and offset slightly inwards to cater for the difference PCD. ANyone tried it?
If this was doable I'd swap a set of 1100 drive flanges for mini ones...
Madmorrie
Users browsing this forum: fuzzy-hair-man and 86 guests
