It is currently Fri Jul 18, 2025 9:06 pm
 Post subject: tacho
PostPosted: Tue May 20, 2008 11:20 pm
hey guys, what is teh diode taht i need for the mini to make the tacho behave properly?
and where would i find one?
cheers jamie
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Wed May 21, 2008 10:15 am
what sort of tacho is it?
mine doesn't need one :? not sure if I've ever heard of needing one before...
PostPosted: Wed May 21, 2008 10:36 am
its a monsta brand one of ebay.
i ahve seen posts on here about adding resistors etc to fix t
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Wed May 21, 2008 11:58 am
A general purpose diode should be OK - depends on the current being drawn you can get them in 1 amp or 3 amp and the voltage rating can be 400 or 1000 volts
If you want to be safe grab a 3amp 1000volt - 25cents won't break the bank and you have some overkill to help cope with the heat if it's in the engine bay that's a 1N5408 or a 1Amp 400 volt is 1N4004 - most commonly used yet is 40c each :?
edit; Jaycar prices
PostPosted: Wed May 21, 2008 12:50 pm
Go the whole hog and get a BYW96E
