It is currently Sun Jul 27, 2025 3:58 am
PostPosted: Sun May 25, 2008 11:40 am
could some one tell me how i can tellthe difference between a tin brake master cylinder and a tin clutch master cylinder?????
cheers damian
PostPosted: Sun May 25, 2008 11:56 am
I know there is a bore diameter difference with the plastic tanked master cyls. Not sure bout the tin tank ones though?
PostPosted: Sun May 25, 2008 12:54 pm
Brake has a 'control' valve to hold the pressure a bit longer - leave it out you have a clutch cylinder put it in for a Brake Cylinder. Hanra is right about bore sizes as well can't remember off the top of my head can someone else fill in?
David L
PostPosted: Sun May 25, 2008 12:55 pm
Most common is 0.7" for brake and 0.75" for clutch
Miniworx Centre 0883741299
Online BMW Mini Shop
PostPosted: Sun May 25, 2008 12:59 pm
Clutch Master:
Brake Master:
PostPosted: Sun May 25, 2008 5:02 pm
Apart from bore size as said and the restrictor valve in the brake MC, the tin tank ones are `handed', ie the base flanges are in different positions.
When put together on the car, the spacing between the tanks is greater than the spacing between the MC bodies.
Users browsing this forum: JM1275 and 103 guests
