It is currently Sat Jul 26, 2025 6:21 pm
PostPosted: Sun May 25, 2008 11:40 am
could some one tell me how i can tellthe difference between a tin brake master cylinder and a tin clutch master cylinder?????
cheers damian
PostPosted: Sun May 25, 2008 11:56 am
I know there is a bore diameter difference with the plastic tanked master cyls. Not sure bout the tin tank ones though?
PostPosted: Sun May 25, 2008 12:54 pm
Brake has a 'control' valve to hold the pressure a bit longer - leave it out you have a clutch cylinder put it in for a Brake Cylinder. Hanra is right about bore sizes as well can't remember off the top of my head can someone else fill in?
David L
PostPosted: Sun May 25, 2008 12:55 pm
Most common is 0.7" for brake and 0.75" for clutch
Miniworx Centre 0883741299
Online BMW Mini Shop
PostPosted: Sun May 25, 2008 12:59 pm
Clutch Master:
Brake Master:
PostPosted: Sun May 25, 2008 5:02 pm
Apart from bore size as said and the restrictor valve in the brake MC, the tin tank ones are `handed', ie the base flanges are in different positions.
When put together on the car, the spacing between the tanks is greater than the spacing between the MC bodies.
