It is currently Mon Jul 21, 2025 11:27 pm
 Post subject: new keys
PostPosted: Wed May 21, 2008 10:48 pm
hey guys well long story short my work car was stolen which had my mini keys in it so who do i go see to get some new keys made. I am assuming i will need another barrell ?? is this a mechanix job or a lock smith??
thanks in advance
PostPosted: Wed May 21, 2008 10:52 pm
What is your mini ? If it's a roundie just get all your mini owning mates to bring their keys around and find one that fits (not too many combinations) , if it's a clubbie you can try the same but there were a lot more combinations by then . Otherwise you'd be better with a locksmith who could strip your existing locks , find out what the keys are and remake the keys to suit .
PostPosted: Wed May 21, 2008 11:00 pm
If you know the numbers or can get the car to him, Ken Nelson at Mini Automotive in Ipswich should be able to help.
Steve
PostPosted: Thu May 22, 2008 1:02 pm
its a 77 or 78 mini
what numbers are you talking - vin or body or something else
PostPosted: Thu May 22, 2008 1:10 pm
If you take the car to a locksmith, he will be able to change the lock for you as well as make you new keys. Might be a good idea if they have also got your address in some way via the work car..
PostPosted: Sun May 25, 2008 8:12 pm
marcsvenson wrote:
its a 77 or 78 mini
the lock barrels, bodys have key numbers stamped on them.
also in the cars 'hand book' if you have it.
the numbers relate to the key tooth profile.
PostPosted: Sun May 25, 2008 9:47 pm
I have a master key for office drawers and filing cabinets at work. I found it fits all the locks on my Mini, and the post box, It also works next doors post box..... I have also found once I start the Mini I can simply pull the key out of the ignition barrell. Amazing
