It is currently Tue Jul 22, 2025 9:06 am
 Post subject: how much is it worth ?
PostPosted: Wed May 28, 2008 5:55 pm
i have a 1100 (i think) motor out of my 75 clubman sitting in the back yard doing nothing.
i was thinking of selling it because im strung for cash, how much do you think it would be worth?
it has no modifications and has roughly 81 - 82 000 k's (i'd have to check)
and blows a little bit of weed.
i change the oil every 1-2000 k's and i have only done about 7000 k's since i got it
new thermostat.
flushed radiator.
new ht leads and plugs.
the sump plug is stripped so needs heli coil or the like
engine number: 9H791P/122675
cheers dion
Mearcat wrote:
PostPosted: Wed May 28, 2008 5:58 pm
I is a mookenik
ill take the head off your hands :D
PostPosted: Wed May 28, 2008 6:02 pm
Milatsmadmini
you sure its not something like 99h791
if it is then it is a 998 not an 1100, but it would be worth to check the head on it though :)
and if its just sitting there not started, but not siezed 50-100 bucks id say
EDIT: in saying that though, all comes back to how much people want to spend ;)
PostPosted: Wed May 28, 2008 6:08 pm
9H791P/122675
The only way this can be an 1100 motor is if someone has stuck an 1100 crank in the 998.
An 1100 in a 75 (The last year of the 1100 in Aussie Minis) would have an engine number begining with 101*/ (the * being a 5 or a 6 or something like that.)
PostPosted: Sat May 31, 2008 6:44 pm
sorry the first numbers started with 99
so does that mean its a 998?
Mearcat wrote:
PostPosted: Sat May 31, 2008 6:49 pm
Yes it is a 998 unless someone has stuck a 1098 crank and pistons in there when they reconditioned it.
A very common mod, I have 3 `998' motors here like this. :lol:
PostPosted: Mon Jun 02, 2008 8:53 am
are the 1098 cranks hard to get? like the 1275's?
Mearcat wrote:
PostPosted: Mon Jun 02, 2008 9:41 am
Nope there are still some about, but try and get one that's std, or -.010" sizes.
And crack test before regrinding. :wink:
PostPosted: Mon Jun 02, 2008 10:16 am
i've got one.. :)
