It is currently Wed Aug 13, 2025 7:54 am
 Post subject: carby sizes
PostPosted: Tue Jun 17, 2008 2:20 pm
hi,
just want to know how you tell what size the su is? and whats the difference between a 1.1/4 and a 1.1/2
cheers leighton
 Post subject: Re: carby sizes
PostPosted: Tue Jun 17, 2008 2:30 pm
Leighton wrote:
hi,
cheers leighton
the difference is the throat size, and therefore amount of air that can go through it....
easiest way to tell the size is by the mounting bolts
1.25" - bolts are lined up vertically IE:
o
o
1.5" - bolts are lined up at 45 degrees IE:
o
....o
1.75" - 4 bolts IE:
o o
o o
1.75"s commonly come in 2 varieties, the HS variety has the fuel bowl beside it, the HIF variety has the bowl underneath. 1.5"s also come with the underneath bowl, but they're not common
Measure the throat is the easiest way but also have a look at the stud holes where it mounts onto the manifold , if there are two studs vertically opposed it's an 1 1/4" , if there are two studs diagonally opposed it's an 1 1/2" , if there are 4 studs it's an 1 3/4" .
PostPosted: Tue Jun 17, 2008 2:47 pm
the hs4 or inch and a half is physically bigger than the hs2 or inch and a quarter.
in addition the hs4 uses a doughnut shaped air filter that totally surrounds the carb, wheras the hs2 has a smaller round airfilter box next to the carb.
also you can tell by the nuts that attach it to the.... :lol:
PostPosted: Tue Jun 17, 2008 5:32 pm
Forum Graffiti
1/4 of an inch :P
PostPosted: Tue Jun 17, 2008 5:40 pm
If any one does not know what a HIF44 looks like
PostPosted: Tue Jun 17, 2008 6:59 pm
poorn :twisted:
PostPosted: Tue Jun 17, 2008 8:39 pm
gafmo wrote:
ohhhh ahhhh.....shiney!!!! 8)
PostPosted: Tue Jun 17, 2008 9:19 pm
Pfft... those seem to give more trouble than an HS6 does! :lol:
[dons flameproof suit] 8)
PostPosted: Tue Jun 17, 2008 9:26 pm
A bloke on the 1100 mailing list was having trouble with a flat spot in his fairly worked Austin 1300 at higher speeds, he tried a lot of things to cure it and in his desperation he removed the HIF44 (1¾") and stuck on the stock HS4 (1½"). It didn't cure the flat spot (which he found was a dodgy plug lead) but it did improve the pick-up and drivability so much that he is sticking with the HS4.
PostPosted: Tue Jun 17, 2008 10:38 pm
thanks for the reply's- tommorow i will have a look at what ive got..... cheers leighton
Users browsing this forum: No registered users and 278 guests
