It is currently Sat Jul 19, 2025 6:17 am
 Post subject: 8000rpm Smiths tacho
PostPosted: Sat Jun 21, 2008 8:12 pm
Can someone please identify my tacho.
It's an aussie one, switchable between 4, 6 and 8 cyl. Are they all switchable?
PostPosted: Sat Jun 21, 2008 8:22 pm
Are there any numbers on the face? Down near where the needle comes 'out'.
How many wires come from the back, and what colour are they?
Is there a seperate bulb holder or is it built in?
It looks very similar to one I have, except it only had two wires with a seperate bulb holder, that attached near the front, under the main body.
Matt
PostPosted: Sat Jun 21, 2008 8:26 pm
Matt
M6601
Two wires from the rear - grey and grey w/ black (or are they meant to be white? - sorta looks like speaker wire to me though!)
Bulb holder underneath - green and red wires
PostPosted: Sat Jun 21, 2008 8:40 pm
Not your traditional smiths tacho, I'm not sure where this one comes from but they weren't typically switchable. They're pretty agricultural typically if you open one up.
I would guess however that this was aimed squarely at the aftermarket, as if you are going to make 10,000 units for a model of car, you won't waste your money on a 4,6,8 cylinder switch.
PostPosted: Sat Jun 21, 2008 9:31 pm
willy wrote:
M6601
Yep, that's the one I have.
Could never ID it. Asked a few Instrument repair places, and a few classic car forums, no-one had any idea. Mick's idea of an aftermarket one is a good one.
To hook it up:
The bulb hooks in like any bulb.
The Grey, Grey Black Trace wires go to the coil, in a negative earth car, the G/B wire goes to the the positive, Grey goes to negative.
That's how I hooked it up to mine, Well I think it is, can tell you next week when I'm working on it. (Stored at a friend's house, can't get back till next saturday :roll: :roll: )
If you need to know sooner, let me know, I'll see if I can get someone to go check it before then.
These are pics from the inside, just for interest:
M
