It is currently Sat Aug 23, 2025 1:52 pm
PostPosted: Sun Jun 22, 2008 12:10 pm
Hi guys
What parts a compatible between a morris 1100 and a mini?
as many parts as you can think of.
Ryan
Ryan Filippi
Minis In The Gong
[email protected]
www.minisinthegong.com.au
PostPosted: Sun Jun 22, 2008 12:19 pm
Engine and gearbox.
I think that's it.
:D
PostPosted: Sun Jun 22, 2008 12:21 pm
This space for rent
The driver?
PostPosted: Sun Jun 22, 2008 12:29 pm
LH driveshaft is same as a Mini RH one.
Speedo cable fits early Clubby.
CVs are the same as Cooper S & later disc braked Minis.
PostPosted: Sun Jun 22, 2008 1:12 pm
You need to swap the steel camsshaft plate for a mini one as the 1100 one has engine mounts built into it.
The 1100 has a slightly different remote change design so you also need the 1100 one when you do the change over.
Mike
PostPosted: Sun Jun 22, 2008 2:44 pm
Forum Graffiti
This would be really handy for me to follow...
I've bought an A+ Rover auto engine and box and I'm trying to figure out how it's going to fit :?
Anything I should know engine mount wise, etc? :)
...Oh, into an 1100 :wink:
PostPosted: Sun Jun 22, 2008 3:04 pm
Mike
Nah, just give it a mountectomy with Mr Anglegrinder... :wink:
PostPosted: Sun Jun 22, 2008 5:25 pm
The inside door handles are the same as Aussie Minis (before lift up handles)
Master cylinders.
Headlight buckets.
PostPosted: Sun Jun 22, 2008 8:22 pm
dash switches if you're not fussed about the same nut
PostPosted: Sun Jun 22, 2008 9:01 pm
rust :lol:
Users browsing this forum: No registered users and 215 guests
