It is currently Tue Jul 22, 2025 1:56 pm
 Post subject: This would be hard work
PostPosted: Thu Mar 19, 2009 6:11 pm
http://cgi.ebay.com.au/Morris-Minor-Manual-Fuel-Pump_W0QQitemZ150332307536QQcmdZViewItemQQptZAU_Car_Parts_Accessories?hash=item150332307536&_trksid=p3286.c0.m14&_trkparms=66%3A4%7C65%3A1%7C39%3A1%7C240%3A1318
David L
PostPosted: Thu Mar 19, 2009 6:19 pm
It needs a longer lever, preferably one with a hand grip.
PostPosted: Thu Mar 19, 2009 6:50 pm
they work alright if you rig them up to some bike pedals... that's what wives are for, you get them to pump the fuel while you drive - the faster you go, the more weight they lose
PostPosted: Thu Mar 19, 2009 6:53 pm
I suppose you could hook it to the camshaft and make it into a mechanical fuel pump, would that work? :?
PostPosted: Thu Mar 19, 2009 7:00 pm
Tomboss Breweros
I have one of those, Really sux when fanging it through the hills.
No electric fuel pump issues though :wink:
kimini wrote:
Jimmyinamini wrote:
PostPosted: Thu Mar 19, 2009 7:01 pm
maybe... but where?? - the oil pump is at one end, and the timing gear is at the other - it's not like you could put it half way along
PostPosted: Thu Mar 19, 2009 7:08 pm
Only SU pumps have electrical problems, SU = Self Unadjusting... :lol:
PostPosted: Thu Mar 19, 2009 7:12 pm
Maybe you could stick it halfway along but it would be a struggle. You would have to pull the manifold off to get near it.
It would be much easier to stick it near the radiator and let the fan knock the arm to operate the pump. You would get 16 pumps per revolution depending on the fan.
PostPosted: Thu Mar 19, 2009 7:13 pm
only use Electrice none Points fuel pumps 8) facet
