It is currently Sat Jul 26, 2025 12:53 am
 Post subject: my diff, URGENT
PostPosted: Wed Sep 03, 2008 8:11 pm
hey thier well time fir some help again
i was driving to work and my front wheels kept looking, so what did i do stopd it and walkd to work lol calld a tow truck n took it back home
i knew it had something to do with the diff so i took out the engine and pulled apart the diff and found that the diff pin had shot out and was going around and broke the case hmm no good at all
pulled apart the actull diff and behind the copper washes is completly stuffed and now im stuck and dont know what to do :(
where would i be able to find a new housing/2nd hand
any other ideas please
PostPosted: Wed Sep 03, 2008 8:25 pm
If you know what type of diff it is then you should be able to pick up a second hand housing pretty easily, the same goes for the crown wheel and pinion (if they are stuffed), the side covers, planet gears and outputs...
Rebuilding something like this 'properly' is a costly exercise though, after you add up all the stuff. I would be asking myself why the diff pin broke in the first place... Do you like doing burnouts?
PostPosted: Wed Sep 03, 2008 8:31 pm
lol well nah the pin that was holding the the main diff pin wasnt strong n spilt, it looks like a water jacket
my dad called mini clinic and they said that they could repair the housing about 200$
PostPosted: Wed Sep 03, 2008 8:42 pm
The Mini King
I am not sure what model mini you have Is the gearbox a rod change or a remote type,
and is the gearbox housing damaged oronly the diff housing
PostPosted: Wed Sep 03, 2008 8:45 pm
well i have an innocenti
the gear box is a lil damaged but iv got the parts from a spare engine to fix that
the real problem that i have is that where the copper washers go behind it it has been all chewed up
PostPosted: Wed Sep 03, 2008 8:50 pm
The Mini King
This is the hemisphere housing, Is this any good in your spare Any mini Hemisphere housing will do the job
PostPosted: Wed Sep 03, 2008 9:09 pm
well iv opend up my other Hemisphere housing and its the same all chewed up :(
thats the housing that i need
PostPosted: Wed Sep 03, 2008 9:14 pm
The Mini King
If You Like give me a call tomorrow 02 46481233 I will have a look see if i have any good ones second hand
PostPosted: Wed Sep 03, 2008 9:16 pm
ohh k hmm what time can i call bcoz i wont be able to have my phone on me 2morrow
ill get my dad to give u a call if u want
Users browsing this forum: Bing [Bot] and 93 guests
