It is currently Sat Aug 16, 2025 11:04 pm
PostPosted: Mon Oct 13, 2008 4:17 pm
had a rear lockup problem on the racetrack, this looks like a bias valve, but does it have the right brake cyls?
PostPosted: Mon Oct 13, 2008 4:32 pm
That is the brake limiting valve (not quite the same thing as a bias valve)
Can't tell which rear cylinders you have without taking off the drums.
I take it you have discs up front?
PostPosted: Mon Oct 13, 2008 4:52 pm
you should have 5/8" wheel cylinders
PostPosted: Mon Oct 13, 2008 7:01 pm
also be aware that the limitimg valve is not the same for all mini variants as they all have different shut-off pressures. What works on a Cooper S would not work correctly on an 850. How you tell the difference I don't know.
1964 998 Cooper , 1968 Morris 1100
PostPosted: Mon Oct 13, 2008 7:23 pm
did you change the rear cylinders when you put discs on?
blokeinamoke wrote:
PostPosted: Mon Oct 13, 2008 7:31 pm
You pull them apart and compare the length of the spring found within. One is longer than the other by a fair margin. I think it's the disc type which is shorter from memory..
PostPosted: Mon Oct 13, 2008 7:39 pm
I did the wife's car, AFTER I had a big sideways braking moment on the F3 at 110KMH... :shock:
John is right, there are various valve settings-
850 early 250-300psi, late 450psi, van 450psi
998 Deluxe 370psi, late 390psi
Mini Minor early 450psi, late 390psi
998 MiniMatic, Moke & van 390psi
998 Cooper 450psi
997 Cooper early 250-300psi, later 450psi
1098 Mini 1100 saloon, van, BMC Moke, Clubman 390psi
1275S, Clubman GT 370psi
1275 Moke 390psi.
PostPosted: Mon Oct 13, 2008 8:04 pm
well its a 75 leyland mini with 7.5" discs on the front, spaced drums on the back..
it came with the discs on it, so i dont really know what has been done at the back
PostPosted: Mon Oct 13, 2008 8:45 pm
I'd put 5/8" S cylinders on the back like I did with our roundy (all Clubby S brake setup but S front discs).
You will have to drill new dowel holes in your backplates, Cooper S backplates had them in a different spot.
PostPosted: Tue Oct 14, 2008 4:29 pm
thanks, will do that!
Users browsing this forum: No registered users and 352 guests
