It is currently Sun Aug 17, 2025 8:42 pm
 Post subject: sc12 parts
PostPosted: Thu Sep 18, 2008 9:53 pm
hi all i picked i up a sc12 or sc14 at a swapmeet the other day but it is missing the pully setup, so i need the whole lot the middle bit that goes onto the shaft and a pully to run around 6psi.
are there any markings on the sc14 and can anyone tell me if the pullys are the same on both?
thanks gary
 Post subject: Re: sc12 parts
PostPosted: Thu Sep 18, 2008 10:04 pm
gary
Hi ya Gary the Sc14 has a Dip stik which is yellow
top right
PostPosted: Tue Sep 23, 2008 9:32 am
thanks i have a sc12 then.
PostPosted: Tue Sep 23, 2008 12:44 pm
SC12 should be clearly embossed on the body on the supercharger.
PostPosted: Tue Sep 23, 2008 7:53 pm
My SC12 has a yellow dipstick so you can't use that to distinguish between SC12 and SC14. It does have SC12 cast on to the body.
I was told the other day that the SC12 has a restrictor in it which if you remove will give about 16psi instead of the standard 7psi.
PostPosted: Tue Sep 23, 2008 8:30 pm
Yep I was wrong :roll:
Here's a handy link for you all 1/2 way down the Page
http://www.autospeed.com/A_110294/cms/article.html
PostPosted: Mon Oct 13, 2008 8:43 pm
mine has a alloy dipstick the same as the charger.
PostPosted: Mon Oct 13, 2008 8:45 pm
but there is nothing on it at all that says what it is.
PostPosted: Mon Oct 13, 2008 9:00 pm
Note the differances between the brackets
SC12
sc14
PostPosted: Mon Oct 20, 2008 11:37 pm
that helps, thanks i have a sc14.
Users browsing this forum: watsupskip and 353 guests
