It is currently Sun Aug 17, 2025 1:10 pm
 Post subject: subframe removal
PostPosted: Sun Oct 26, 2008 7:36 pm
I'm thinking of painting my mini again. question? Can I unbolt the hyrdo subframes and lift the body shell up without draining the hyrdo.. Thinking of getting it soda blasted. and then repainted.
PostPosted: Sun Oct 26, 2008 7:37 pm
You will need to drain it.
PostPosted: Sun Oct 26, 2008 9:14 pm
Front hydro bag lines will not let the subframe drop untill you undo them.
PostPosted: Sun Oct 26, 2008 9:16 pm
Yeah, the front flexible hydro hoses pass through the engine bay cross member. You would have to gas axe the car to get the pipes out.....other than that little show stopper it might have worked :)
