It is currently Sat Jul 19, 2025 2:58 pm
 Post subject: help! Mini wont start
PostPosted: Thu Feb 10, 2005 5:33 pm
okay, got a battery with plenty of charge, new spark plugs, points, rotor, dizzy cap, condensor.
no spark is coming from the plugs or is seen between the points
coil is getting hot
starter motor turns over quickly
points filed
carb seems okay and float bowl full of fuel
please help :shock:
PostPosted: Thu Feb 10, 2005 5:47 pm
if the coil is working and there is no spark id say dissy cap. Have you got a spare? check the little black wire in there,, mine broke once and wouldnt start.
1974 Moke - 998cc
PostPosted: Thu Feb 10, 2005 5:51 pm
is your low tension lead between coil -ive and condenser connected ?
has happened to me :)
PostPosted: Thu Feb 10, 2005 5:56 pm
Yep check the cap it could be cracked...Check all your eaths again also
PostPosted: Thu Feb 10, 2005 7:19 pm
brand new cap :(
might it be the engine to body earth?
the car was tow started yesterday so i know it should run
thanks for the suggestions
PostPosted: Thu Feb 10, 2005 9:32 pm
If you've put a new condenser in check that the tag is not under the insulating washer - don't ask how I now the car won't start if you do this :oops:
PostPosted: Fri Feb 11, 2005 11:57 am
regardless of the dizzy, there is no high voltage spark from the coil HT lead.
what am i looking at here? starter switch?
PostPosted: Fri Feb 11, 2005 12:04 pm
coil could either be wired wrong or faulty, change it and try again,
lookin for another clubby
PostPosted: Fri Feb 11, 2005 12:06 pm
yeah i have tried with 2 different coils so i dont think its the coil
PostPosted: Fri Feb 11, 2005 12:12 pm
Have you checked out the lead from the coil to the dizzy?
Mine was RS and I wondered why my mini was running badly :roll:
There is no spark at any of the plugs right? :?:
There are wires going up through the ignition that if unplugged will stop it starting / sparking, look for some white wires joined by round plugs (where the tacho would connect in)
Roads need more corners
PostPosted: Fri Feb 11, 2005 1:09 pm
yeah the HT lead from the coil to dizzy is a new one
theres something funny going on with the ol electrics
PostPosted: Fri Feb 11, 2005 1:25 pm
With the ignition on - open the points by lifting the arm and see if you get a spark at the contacts and tell us what happens
PostPosted: Fri Feb 11, 2005 1:36 pm
no spark
PostPosted: Fri Feb 11, 2005 1:53 pm
we tested both the coils by connecting a battery to the terminals and getting a spark from the HT lead, so the coils and the leads are okay
PostPosted: Fri Feb 11, 2005 3:08 pm
Is there 12volts at the distributor with ignition on? ie before the condenser
