It is currently Wed Aug 20, 2025 2:50 pm
 Post subject: Hinge parts
PostPosted: Tue Nov 04, 2008 7:28 pm
Alright... got my hinges kitted by Rob Ford, thanks heaps mate.
Now I just need the fixings for it - studs, washers, nuts, and bolts.
Am I assuming correctly that I need the studs on the rear most part of the hinge, and then a bolt the next one forward from that -still on the door.?
And then... I will need all the studs etc that I have mentioned.
Is anyone able to help or point me in the right direction?
Thanks in advance.
PostPosted: Tue Nov 04, 2008 7:35 pm
They are all studs, except the forward one on the door.
I bought some 1/4 UNF bolts with full thread, and cut the heads off. :wink:
PostPosted: Tue Nov 04, 2008 8:22 pm
yeah me too, I tried everywhere even motor traders. They would sell like hot cakes if you could find a whole bunch of them. Cutting ems a lot of work :(
PostPosted: Tue Nov 04, 2008 8:46 pm
willy,
This Chart may be of some use to you!
Bit tatty now but tells the story!
Dave
PostPosted: Tue Nov 04, 2008 9:06 pm
What about all the boot hinge ones at my shop?
we never looked at them.
Miniworx Centre 0883741299
Online BMW Mini Shop
PostPosted: Tue Nov 04, 2008 9:09 pm
Dave, good work, that should help heaps.
Steve, you make a good point.
I'll pop in on Saturday and check it out
PostPosted: Tue Nov 04, 2008 9:14 pm
Bloody boot hinges.... the cast alloy strips threads so easy. UNF there was a poor choice.
I had to make some stepped studs, 5/16 UNC bolts mostly turned down to 1/4 UNF, after I tapped the boot hinges to 5/16 UNC.
PostPosted: Tue Nov 04, 2008 9:18 pm
made from high quality alfoil
PostPosted: Tue Nov 04, 2008 9:25 pm
*notes to self for mini assembly next week....tighten boot hinges carefully...*
PostPosted: Thu Nov 06, 2008 10:13 am
You can get a kit from minispares made out of stainless if you're interested...
http://www.minispares.com/Product.aspx?ty=pb&pid=38539&title=DOOR%20HINGE%20BOLT%20KIT%20FOR%20M...
PostPosted: Thu Nov 06, 2008 5:53 pm
Butchers stripping threads.... Insted of taping them out to the next size, why wouldn't you use a Helicoil or Recoil depending on the brand, thats what I used and you won't strip the thread again!!!! Unless you are a vey special person... It would make sense.....
Luke, you should know willy by now!!!!! You know he can't wait... :P :P
PostPosted: Thu Nov 06, 2008 6:53 pm
Hey, I inherited this car, it probably had 6 owners before me... it wasn't me that overtightened them.
Have you seen how few 1/4 UNF threads there are, in the bottom boot hinge stud hole??? :twisted: A helicoil in there would have all the strength of 1/2 a bent paperclip....
A stepped stud is stronger, UNC threads deeper (best for alloy) it won't come out anytime soon- Mr Loctite 262 is holding it fast. 8)
Anyway, I have lathe, can make.... cost was zip, and the hinges still look original, just better. :D
I could have just used 5/16" UNC studs and drilled the bootlid, but nah...
PostPosted: Thu Nov 06, 2008 10:22 pm
Try united fasteners at cavan. I bought a heap about 4 months ago. They only had 1 1/2" long,but the short thread was the right length and cut off the excess
www.minisprintgt.com
Users browsing this forum: No registered users and 195 guests
